Thread: Occasionally won't start.
Results 1 to 6 of 6
  1. #1 Occasionally won't start.
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I have a 2001 Grand Prix GT with a SS M90 supercharger setup, as well with the mods in my signature. Just last week, I went to start my car and it wouldn't start. It would just crank. I gave it gas for a second or two (while cranking) and it started up and ran fine. It's only happened about 3 times in 2 weeks, but I'm worried something is failing, and it won't start at all. I had a no-start problem a few months ago, but it would die no matter what (as soon as I let off the gas). I cleaned up the TB screen, the MAF sensor and the IAC valve, and it fixed it. Could it be related to this? I have new spark plugs, pretty new wires and a new fuel filter. Thank you.
  2. #2 Re: Occasionally won't start.
    Bump! Please guys!
  3. #3 Re: Occasionally won't start.
    Bump.
  4. #4 Re: Occasionally won't start.
    St. Louis
    Fuel pump resistor comes to mind. Search for that and see what comes up. Have you tried unplugging the MAF and seeing if it starts ok?
  5. #5 Re: Occasionally won't start.
    Jul 2008
    sumter,south carolina
    check fuel pressure at the check valve?
    02 GTP with mods 05 GP for DD
  6. #6 Re: Occasionally won't start.
    I don't think the fuel pump resistor was an issue with the GT's, only the GTP's. Correct? Next time the car does this, I'll check the fuel pressure, and unplug the MAF and see what happens. Thanks guys.
  1. Help, Car Won't Start.
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2010, 09:58 PM
  2. Rev's at start up
    By 2003GPGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2010, 06:58 PM
  3. HELP Will not start
    By chuckd98gtp in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2009, 01:23 AM
  4. 04 gtp, tic tic tic tic when trying to start
    By busagtp in forum General Tech Discussion
    Last Post: 08-31-2009, 08:26 AM
  5. Occasionally Sputtering then back to normal? Help
    By Abrasive in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2009, 10:57 PM
