Thread: Worlds Smallest V-8
Results 1 to 10 of 10
  1. #1 Worlds Smallest V-8
    Banned
    Sioux Falls, SD
  2. #2 Re: Worlds Smallest V-8
    Grand Island, Nebraska
    Still sounds better than a 3800
  3. #3 Re: Worlds Smallest V-8
    Apr 2012
    Bancroft. Ontario, Canada
    thats pretty awesome!! (would be sweet for a r-c airplane) or truck
  4. #4 Re: Worlds Smallest V-8
    Sep 2011
    Copperas Cove, TEXAS
    That was F N impressive.
  5. #5 Re: Worlds Smallest V-8
    Panama City Beach, FL
    Neat, but Conley's ish > That.
    http://www.conleyprecision.com/
  6. #6 Re: Worlds Smallest V-8
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    weberprecision1
    I saw this one a few years back, cool as hell!
    4 out of 3 people have trouble with fractions
  7. #7 Re: Worlds Smallest V-8
    GTX Level Member Juanmiguel's Avatar
    Mexico
    how much would one of those cost? I'd love to have one.
  8. #8 Re: Worlds Smallest V-8
    Mexico
    lol nevermind, it almost costs the same as an actual size supercharged V8:
    Unfortunately, the 427 engine that many of you have been so familiar with, is no longer in production. Like the V-10, most of the molds for the 427 engine were destroyed in a catastrophic fire at the foundry. Here is the latest in the Conley line of V-8 engines. It sports the Stinger 609 name badge (6.09 cubic inches or almost 100 cc) and is the culmination of almost 30 years of knowledge gained in the designing and construction of model engines. The new Stinger possesses no parts used in prior V-8 engines. The bore is 1.00, with a .970 stroke. It weighs about 11.25 pounds and measures approximately 14" long (from the front timing belt to the end of the transmission), 6" wide, and 8-1/4" tall. The supercharged version will be about 10" tall. Among the numerous innovative features like large oval shaped intake ports, "D" shaped exhaust ports, and investment cast parts, two bold attributes stand tall: the dry sump pressurized oiling system and a full ignition system. The engine even has a user replaceable oil filter. For those of you who lack familiarity with dry sump oiling, it simply means that oil resides in a holding tank, rather than a conventional oil pan, which circulates throughout the engine. The oil that does collect in the pan is simply pumped back to the holding tank. I have incorporated what is call a "three stage" oil pump to move all the oil. One stage is used to feed oil to the engine, whereas, the other two stages are used to remove all the accumulated oil from the pan. This is particularly important for high acceleration, cornering, or boat applications. An important side note, my test engine held about 20 lbs oil pressure at idle and 60 lbs oil pressure at 9,000 rpm. The dry sump oiling system not only adds more oil volume but aids in engine cooling and makes sure that there is plenty of oil during hard acceleration or sharp corners. The spark plugs have a 10-40 thread. As always, the new Stinger 609 V-8 will have an electric starter as standard equipment. No hand held electric motors here, or something that fits in a box below the engine, but rather a 12 volt electric motor that is an fundamental part of the engine. It can be activated manually or via the transmitter on your remote control. The centrifugal clutch is also included. The cost of the standard engine is $5,695.00 and will show off the standard “Zoomie” style exhaust. At the present time here is a list of the options:
    Exhaust manifolds, cast in 303 stainless steel......................$ 279.00
    Exhaust manifolds, cast in 303 stainless steel - polished ....$ 559.00
    Painted Valve covers and intake manifold.............................$ 125.00
    Supercharger installed and tested..........................................$1 ,695.00
    High duration camshaft (installed at factory only)................$ 279.00
    Transmission with forward-neutral-reverse available in near future.
    Each engine will be fully tested and adjusted for optimum performance. I am expecting around 5.5 hp at 9,500 rpm for the normally aspirated version and about 9 hp for the supercharged version.
    Prices start at $5,695.00
    for the non supercharged version, plus shipping and handling.
    Prices are subject to change without notice.
  9. #9 Re: Worlds Smallest V-8
    Jan 2012
    Philadelphia
    that's awesome not sure what id do with it if i had one though lol
  10. #10 Re: Worlds Smallest V-8
    Quote Originally Posted by gtpeddie View Post
    I'd wreck the Dog's world.
  1. Worlds worst mechanic?!
    By FuglyGTP in forum The Rant Forum
    Last Post: 05-24-2009, 10:59 AM
  2. smallest S/C pulley with no other mods
    By millfire517 in forum General Tech Discussion
    Last Post: 02-20-2009, 03:04 PM
  3. Smallest Pully
    By GP_Kid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 09:51 PM
  4. worlds smallest supercharged v8
    Last Post: 07-26-2008, 09:40 AM
  5. Worlds Fastest Car
    Last Post: 07-25-2008, 09:57 PM
