Thread: Cluster display help?
Results 1 to 14 of 14
  1. #1 Cluster display help?
    SE Level Member codysGS's Avatar
    Port Perry Ontario
    hey on my regal the cluster display, gear indicator/ mileage etc is unlit/ burnout.... i can live with that but the DIC started to act funny today... its been dim from time to time but finally when out... it came back with banging on the dash?
    Is it simply that a connection is loose and my need re sautered? or bulbs or?
    Well thanks for reading
    here's a pic once the DIC came back on http://i1198.photobucket.com/albums/...TQyNy5qcGc.jpg
    My rides: 1986 Pontiac Fiero GT fastback 300 SeriesII NA manual
    1999 Buick Regal GS, fenderwell intake, 5 percent tint all round SOLD
    1986 Pontiac Fiero SE 2M6 blown up 3.8na GONE 1989 GMC S15- Derby truck
  2. #2 Re: Cluster display help?
    here ya go
    http://www.grandprixforums.net/how-f...tml#post503775
    Being a Regal, do all 10 resistors. It's relatively quick and easy. Holler if you have any questions. BTW..while you are there, is your HVAC dim at all or moody? Great time to fix that too. I'll post that fix.
    http://www.grandprixforums.net/how-f...tml#post503777
  3. #3 Re: Cluster display help?
    Port Perry Ontario
    Thank you so much! HVAC unit is good Thanks again
  4. #4 Re: Cluster display help?
    Port Perry Ontario
    Question!: just went to buy the resistors, and local radio shack doesn't sell more then two 180s per pack, we dug throughg everything they had and found 2, I was wondering is it the resistor that fails or the sauter holding them on?
  5. #5 Re: Cluster display help?
    Uhmmm I'm having a second thought about it being 180, but shouldn't be questioning myself if it's a 180 or 150ohm.
    The resistors will look cooked and either fall off or are already laying int eh bottom of the cluster when you pull it apart. PM on the way.
  6. #6 Re: Cluster display help?
    I double checked and am very sorry.
    150ohm resistors is what you need to replace with. Not sure what the heck I was thinking when I original wrote 180. I have corrected the writeup.
  7. #7 Re: Cluster display help?
    Port Perry Ontario
    no worries, but same situation, the place only had mutipacks with 2 of each. he had a few open packs and let me grab the 180s. So i gotta order some off ebay i guess,
    Only other places they reccomend might have em is over an hour drive so I'll postpone this one for a little while
  8. #8 Re: Cluster display help?
    i had the same problem when i bought my regal. if you have 0 experience soldering you should not try this yourself, the last owner of my car tried to fix it them self and cooked the board, so i wound up having to send my cluster out to be replaced/ rebuilt, and if you need a new one make sure that its for the same year car, they are very different from year to year, the 1 st one the guy sent me was for a different year and the speedo and gas gauge didn't work.
  9. #9 Re: Cluster display help?
    Good thoughts Scott...
    Hey Cody, Scott reminded me about a 99 cluster I have sitting around. Want to play swap clusters and I could fix your up, or..if you want I can pick up the resistors (although I think I have them laying around) and send them to ya.
  10. #10 Re: Cluster display help?
    Port Perry Ontario
    Doesn't that cause theift system issues and what about the mileage, where are you from bill?
  11. #11 Re: Cluster display help?
    Ohhhhh you're up "there" in the land of the north. I'm in CT. Actually the cluster is very easy to fix wtih the resistors. I'm sure you cn do it.
  12. #12 Re: Cluster display help?
    if you sent the cluster out to a repair shop, they can and will download your mileage and put it into a new/ used unit, thats how i found out it had 212,000 miles on my car, had no idea it was that hi when i bought it, last title said 160,000.
    so no stickers on my door, its all done the right way, most of the junk yard clusters are burnt up already and for piece of mind its worth a rebuild anyways.
    the lights burning out are very very common the resistor just vibrate loose over time. same as the climate controls lights.
    mine cost 60 bucks off ebay
  13. #13 Re: Cluster display help?
    Port Perry Ontario
    Thanks, just gotta wait to get some resistors and I'll get it done, thanks for all the info
  14. #14 Re: Cluster display help?
    Port Perry Ontario
    Thanks scotty and bill
  1. HUD Display
    By 04gpking85 in forum 04+ Specifics
    Last Post: 03-06-2010, 01:09 PM
  2. Radio display seems hot ??
    By NICK2001GP in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2010, 08:33 PM
  3. Cannot See my Radio's Display
    By y1a3o in forum Audio, Security & Visual Electronics
    Last Post: 03-12-2009, 09:04 PM
  4. Center Display Help
    By Forrest in forum General Tech Discussion
    Last Post: 03-06-2009, 09:58 AM
  5. heads up display
    By dmoney01 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:36 PM
