Thread: heads up display
Results 1 to 5 of 5
  1. #1 heads up display
    Jan 2009
    hammond, IN
    my heads up display wil lturn on and work good for about a minute or two and then slowly fade off until it is gone. any body know ehat the problem could be?
  2. #2 Re: heads up display
    GT Level Member BackInBlack's Avatar
    Vermont
    The most common problem is the poor solder joints on the light load sensor. All you need to do (easier said than done) is to pull out the HUD driver, clean off the conformal coating on the PCB and re-solder the leads to the photo sensor.
    The GPs are long gone...
  3. #3 Re: heads up display
    Jan 2009
    hammond, IN
    oh ok cool ill try and let you know, but do i need to soder anything back together?
  4. #4 Re: heads up display
    Vermont
    Yes. Just re-flow the solder on the pins of the sensor. It looks like a small silver can with a clear some on the top. You can see the sensor inside.
  5. #5 Re: heads up display
    Jan 2009
    hammond, IN
    ok thanks ima try that tommorrow morning
  1. Heads Up Display Gets Dim After 20 miles of driving
    By Skillet in forum General Tech Discussion
    Last Post: 01-05-2009, 02:10 PM
  2. heads up display
    By bb52190 in forum General Tech Discussion
    Last Post: 09-26-2008, 04:30 AM
  3. I built a heads-up display (HUD).
    By drranu in forum General Tech Discussion
    Last Post: 08-19-2008, 06:30 PM
  4. Heads Up Display
    By shamb1s in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2008, 12:34 PM
  5. display flashing
    By Chleby in forum Audio, Security & Visual Electronics
    Last Post: 01-03-2008, 04:43 PM
