OKay.... well the regulator is good and i have 50 psi at the rail now. (must of been a bad test before)
I pulled out my spark plugs and they were shot... so i put new ones in. They were covered in gas and had all kinds of build up on them. My MAF sensor was bad so i think it was putting too much gas in. SO before i put in my new spark plugs i did a compression test.... i have 150 across the board except the front middle cylinder which is giving me 0!!!!!!!!! I dont like it... But if it was a head gasket wouldnt i get lower compression on more than one? the other five are fine!.... maybe its all gummed up and clogged from the gas/carbon built up. When i did the pressure test it was sucking up all kinds of build up. So what do you guys think? hopefully not a head gasket..... i don't have the money to fix that.
