Thread: 01 gtp engine swap
Page 5 of 22 FirstFirst ... 3456715 ... LastLast
Results 81 to 100 of 422
  1. #81 Re: silver 01 gtp rod knock already...
    SE Level Member johndaysGT's Avatar
    Seymour, TN
    Excessive piston slap occurs when the clearance between the piston and the cylinder bore is too great. The piston to cylinder bore clearance becomes too great either through wear, mismatched pistons and cylinder bores at manufacturing or, a combination of both. The audible noise associated with excessive piston slap is due to the perpendicular impact of the piston against the wall of the cylinder bore. Audible piston slap is typically loudest when the engine is first started up. The pistons then expand with heat reducing the piston to cylinder bore clearance thus, reducing the perpendicular impact of the piston against the cylinder wall and its resulting noise.
  2. #82 Re: silver 01 gtp rod knock already...
    Seymour, TN
    I just copied and pasted it. Too much to type from a smartphone.
  3. #83 Re: silver 01 gtp rod knock already...
    Quote Originally Posted by 98buicksupercharged View Post
    then why can I feel the hard know when I touch my oil pan?
    grab a valve cover, i bet you feel it up top more. the engine is metal, a knock can and will travel sound wise. or get a wood dowel or large screw driver to your ear.
  4. #84 Re: silver 01 gtp rod knock already...
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    don't feel it in a valve cover or hear it as well up top
    2001 sliver gtp her name is Reagan
  5. #85 Re: silver 01 gtp rod knock already...
    it could be piston slap then, but thats would be in the cylinder, as well as a lifter, its dead center of the engine.
    sea foam it, see what happens, it cant hurt. dont put it in the oil tho, just the gas tank and in the vac line.
  6. #86 Re: silver 01 gtp rod knock already...
    Oct 2012
    Fort Wayne, Indiana
    alright sounds good
  7. #87 Re: silver 01 gtp rod knock already...
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    My oil pickup tube broke where the plate bolts to the block, but was still hanging on by a thread. It would knock like Crazy when I first cranked it for a couple minutes, then would slowly go away.
    I found it when I pulled my pan off to check the crank and rods.
  8. #88 Re: silver 01 gtp rod knock already...
    Is it me or are you looking for a reason for it to be rod knock?
    You really should be happy..I think it's a lifter as well. Change your oil don't be so quick to assume that it's the bottom end. Check the lifters!!! We're trying to save you a bunch of money lol.
    04 Comp G.
  9. #89 Re: silver 01 gtp rod knock already...
    Oct 2012
    Fort Wayne, Indiana
    Haha I don't want it to be rod knock. I just think that's what it is. I'll obviously check the lifters to make sure first. And already did and oil change
  10. #90 Re: silver 01 gtp rod knock already...
    GTX Level Member AKGTP19's Avatar
    Mar 2013
    Fort Lauderdale, FL
    Check your belts brotha
    1998 GTP Loudmouth
    1999 GTP, Borla Cat Back.....SOLD
  11. #91 Re: silver 01 gtp rod knock already...
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    im gonna say it doesnt sound like a rod knock to me, my engine sounded much worse when it let go. get it on some jack stands and check the flex plate, id bet its either damaged a tooth because of wear, or its shaking around while running. if not, pull out a long screw driver and narrow down where its coming from, its really hard to tell with out a listening device, ive seen a bad flex plate that we swore was a supercharger coupler before just because how hard it is to pin point the origin of sound
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  12. #92 Re: silver 01 gtp rod knock already...
    Oct 2012
    Fort Wayne, Indiana
    Alright sounds good
  13. #93 Re: silver 01 gtp rod knock already...
    Just beat the hell out of it until it breaks and then see what breaks lol
  14. #94 Re: silver 01 gtp rod knock already...
    Oct 2012
    Fort Wayne, Indiana
    Kinda been what I have been doing haha
  15. #95 Re: silver 01 gtp rod knock already...
    Mar 2013
    Fort Lauderdale, FL
    Yeah just find a highway merge and jam the gas then parking lot, couple burn outs, maybe some reverse J turns, the fun stuff a 4000lb vehicle hates lol
    1998 GTP Loudmouth
  16. #96 Re: silver 01 gtp rod knock already...
    Oct 2012
    Fort Wayne, Indiana
    Well I'm basically gonna but a new motor that has 90k on it. Series 2. And just build that a little bit. Keep driving the car until motor goes out or what ever that noise is breaks and swap out motors. Also if the guy still has them I'm buying pre gens on Friday. Going to spray them gun metal, black, or silver
  17. #97 Re: silver 01 gtp rod knock already...
    Cam the motor while it's out. You won't regret it.
  18. #98 Re: silver 01 gtp rod knock already...
    Oct 2012
    Fort Wayne, Indiana
    Plan on that and headers. And found a gen v for 250 bucks I'm gonna try and buy Friday
  19. #99 Re: silver 01 gtp rod knock already...
    Gen V are a waste of money to me, you'll end up spending way more than that 250 bucks just to swap a blower.
    Port the gen 3 and drop another pulley size. 50 bucks > 400 bucks for the same horsepower.
  20. #100 Re: silver 01 gtp rod knock already...
    gen v whine louder though and are more efficient. I'd do the swap if you have the money to spend.
  1. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
