Nice work kind of make me glad I don't have a sunroof.
your gxp doesnt have a sun roof
Dude just go buy a new sunroof assembly. Your's looks jacked.
How does it look jacked
All that caulking everywhere to seal it up. I got mine from the junkyard for $150 bolted it up and have had no problems with it
interesting. i really dont know how its leaking. i went over board with the caulking but is there a seal around in there somewhere? i know theres a 07 gp with sunroof at the local pick n pull that hasnt hardly been touched except for the supercharger and LIM
Go get it and swap it out. Grab the drain hoses too
sounds good! i dont got the funds for it now so the caulking will have to work for awhile
.......i dont want one anymore. their nice...until they leak. then their a pain
well i can do better to...just didnt care cause it cant be seen when put back together
Nah no sunroof here I have one of the rare gxp's. They shouldn't charge you more than 100 for that sunroof. Oh and BTW if you go see if you can swipe that 5 button dic for me I will Gladly pay you for your time.
Yea I'll swipe it....its still there or was last month
Alright so here's whats going on with the damned car.
1) new tranny cooler going in soon
2) needs new harmonic balancer
3)drivers side ballast is bad....replace for free
4) oil change in 33 miles
Are you sure it was the drains that were clogged? I had the same problem during heavy rain. It turned out that the end of the drain hoses, that run along the pillars were sitting flat/flush up against the sealing foam in the wheel wells, not allowing enough water to pass, making water back up into the sunroof where they start. Soultion was to simply cut the end of the drainage hoses at a 45* angle to allow for easy water flow. Havent had the problem since. I believe there was a TSB about it a couple years ago.
Yea I checked the drainage hoses. I did lots of research on that problem
NOTE: THE TOOLS LISTED AT THE BEGINNING OF THIS POST ARE HYPER LINKED TO THE TOOL SO YOU CAN VIEW IT. DO I REALLY NEED ALL THOSE TOOLS?
Service Information
Crankshaft Balancer Replacement
Tools Required
• EN 47699 Flywheel Holding Tool
• J 41665 Crankshaft Balancer and Sprocket Installer
• J 41816 Crankshaft Balancer Remover
• J 41816-2 Crankshaft End Protector
• J 42640 Steering Column Anti-Rotation Pin
• J 45059 Torque Angle Meter
Removal Procedure
- Install a J 42640 . Refer to Steering Column Replacement .
- Remove the accessory drive belt. Refer to Drive Belt Replacement - Accessory .
- Remove the air cleaner upper housing. Refer to Air Cleaner Assembly Replacement .
- Remove the engine mount strut. Refer to Engine Mount Strut Replacement .
- Remove the starter motor. Refer to Starter Motor Replacement .
- Remove the front fender splash shield. Refer to Engine Splash Shield Replacement .
- Disconnect the transaxle cooler lines at the transaxle. Refer to Automatic Transmission Oil Cooler Hose Replacement .
- Remove the stabilizer shaft link lower nuts. Refer to Stabilizer Shaft Link Replacement .
- Remove the intermediate steering shaft pinch bolt and separate the shaft from the steering gear. Refer to Intermediate Steering Shaft Replacement .
- Remove the front lower air deflector braces and the deflector. Refer to Radiator Air Lower Baffle and Deflector Replacement .
- Remove the radiator to frame braces.
- Install the engine support fixture. Refer to Engine Support Fixture .
- Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
- Remove the frame to body bolts.
- Remove the transmission bellhousing bolt located at approximately the 10 o'clock position when looking from the rear of the engine.
16. Install the EN 47699 and bolt to the block and flywheel.
Tighten
Tighten the bolt to 60 N·m (44 lb ft).
17. Remove the right front tire and wheel assembly. Refer to Tire and Wheel Removal and Installation .
18. Lower the engine approximately 100 mm (4 in).
19. Remove the crankshaft balancer bolt (139).
Do not discard the crankshaft balancer bolt. The balancer bolt will be used during the balancer installation procedure.
20. Install the J 41816 (1) and the J 41816-2 (2), to the crankshaft balancer.
21. Remove the crankshaft balancer (138).
22. Remove the J 41816 and the J 41816-2 from the crankshaft balancer.
Installation Procedure
Important:
• The used crankshaft balancer bolt will be used only during the first pass of the balancer installation procedure. Install a NEW bolt and tighten as described in the second, third and forth passes of the balancer bolt tightening procedure.
• The crankshaft balancer installation and bolt tightening involves a four stage tightening process. The first pass ensures that the balancer is installed completely onto the crankshaft. The second, third, and forth passes tighten the new bolt to the proper torque.
Important: The balancer should be positioned onto the end of the crankshaft as straight as possible prior to tool installation.
1. Position the crankshaft balancer (138) onto the end of the crankshaft.
2. Using the J 41665 , install the crankshaft balancer.
2.1. Assemble the threaded rod, nut, washer and installer. Insert the smaller end of the installer into the front of the balancer.
2.2. Use a wrench and hold the hex end of the threaded rod.
2.3. Use a second wrench and rotate the installation tool nut clockwise until the balancer is started onto the crankshaft.
2.4. Remove the tool and reverse the installation tool. Position the larger end of the installer against the front of the balancer.
2.5. Use a wrench and hold the hex end of the threaded rod.
2.6. Use a second wrench and rotate the installation tool nut clockwise until the balancer is installed onto the crankshaft.
2.7. Remove the balancer installation tool.
Notice: Refer to Fastener Notice in the Preface section
3. Install the USED crankshaft balancer bolt (139).
Tighten
Tighten the USED bolt to 330 N·m (240 lb ft).
4. Remove the USED crankshaft balancer bolt.
Important: The nose of the crankshaft should be recessed 2.4-4.48 mm (0.094-0.176 in) into the balancer bore.
5. Measure for a correctly installed balancer. If the balancer is not installed to the proper dimensions, install the J 41665 and repeat the installation procedure.
6. Install a NEW crankshaft balancer bolt (139).
Tighten
• Tighten the bolt a first pass to 50 N·m (37 lb ft).
• Tighten the bolt a second pass to 140 degrees using J 45059 .
7. Remove the EN 47699 and bolt from the block and flywheel.
8. Install the transmission bellhousing bolt located at approximately the 10 o'clock position when looking from the rear of the engine.
Tighten
Tighten the bolt to 75 N·m (55 lb ft).
9. Raise and properly position the frame and install the frame to body bolts. Refer to Frame Replacement .
10. Install the frame to radiator braces.
11. Install the front lower air deflector. Refer to Radiator Air Lower Baffle and Deflector Replacement .
12. Connect the intermediate steering shaft to the steering gear. Refer to Intermediate Steering Shaft Replacement .
13. Install the stabilizer shaft link lower nuts. Refer to Stabilizer Shaft Link Replacement .
14. Connect the transaxle cooler lines to the transaxle. Refer to Automatic Transmission Oil Cooler Hose Replacement .
15. Remove the engine support fixture.
16. Install the front fender splash shield. Refer to Engine Splash Shield Replacement .
17. Install the starter motor. Refer to Starter Motor Replacement .
18. Install the air cleaner upper housing. Refer to Air Cleaner Assembly Replacement .
19. Install the accessory drive belt. Refer to Drive Belt Replacement - Accessory .
20. Install the engine mount strut. Refer to Engine Mount Strut Replacement .
21. Install the right front tire and wheel assembly. Refer to Tire and Wheel Removal and Installation .
22. Perform the crankshaft position (CKP) system variation learn procedure. Refer to Crankshaft Position System Variation Learn .
ive been inspecting the harmonic balancer and it looks like i may not even need to lower it. i mean i know that their pressed on and all but really all that work for such a simple job?? opinions
drop the cradle a little take off the passenger wheel and brakes,hang up the caliper on the strut, and go to town. GM is smoking on that piece. IMO
