Thread: Starting to build up the intrigue, finally
Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 241 to 260 of 273
  1. #241 Re: Starting to build up the intrigue, finally
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    This doesnt sound to reassuring..
  2. #242 Re: Starting to build up the intrigue, finally
    It's okay Max. I'm here for you.
  3. #243 Re: Starting to build up the intrigue, finally
    May 2012
    CT
    So what's the story with this car?
  4. #244 Re: Starting to build up the intrigue, finally
    Max must be super busy. He had told me he was going to post Wed night.
    Short story made as long as I can:
    Wed the 2nd I recieved a call that he thought something went bad in the valve train when taking some coworkers out to lunch. Erich then called with a dead motor at about 3pm. By 7pm two dead cars had been delievered. Both parked until Saturday.
    Saturday: Max pulled the plugs to find one electrode beated closed. Erich arrived with a motor. While Max plugged away at hsi disassembly Erich and I pulled his and started swapping parts to the new motor. (heads, cam, oil pan, intake, everything except the shortblock.) By the end of the night Erichs was ready to go back in and Max's was ready to pull out and put on the recently emptied engine stand.
    Sunday: Pulled Max's, slapped it on the stand and he pulled the other head off. Erich's was back to running and left.
    Monday: I get out of work a couple hours before Max and jumped on it. By the time he arrived his old L36 was on the stand and stripped to the shortblock. He tossed in the cam, oil pickup and prepped all the block surfaces for reassembly.
    Tuesday: I did a radiator hose on someones car, then hopped to it. Max arrived to find one head awaiting torque and me cleaning the other. He got those torqued down, soon as he did the first final pass I had the pushrods in and was torquing the rockers, intake went on, we were hauling some major butt........then realized we didn't have front and rear engine cover gaskets. Order placed...damnmmmmit!
    Wed: Max arrived early and found the motor sitting in the cradle. To prove it, I disconnected the hoist. From then until 9-9:30 we installed the headers, intercooler core, SC, TB, hooked up the wiring, PS pump, AC compressor, starter, TC bolts name it.. at 9-9:30 he turned the key and it roared to life again. We high fived and called it a night after running it up to temp and topping off the fluids. It's ready for an oil change.
    Thurs-Sun: Max is busy with good stuff and on Sun he'll be by to pick her up. Had Erich's not been there, it probably would have been a two day turn around and run on Sunday.
  5. #245 Re: Starting to build up the intrigue, finally
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    What the hell happened to beat the spark plugs closed.
    97 Bonneville SE Not so much a 97 anymore
  6. #246 Re: Starting to build up the intrigue, finally
    Quincy, Mass
    maxed out the timing but didnt back anything off for safety, then had a car full of people.
    its ok max, yours lasted longer than my is3 build the second time. blew it on the dyno within 24 hours of being completed...
    No more GP 04 Impala SS Indy:
    I live here. DirtDog's Avatar
    Jun 2012
    That sucks. I'm still really looking forward to seeing this beast
    Sent from my DROID RAZR using Tapatalk 2
  8. #248 Re: Starting to build up the intrigue, finally
    Nov 2009
    Central Jersey
    Don't fret it is being rebuilt.
  9. #249 Re: Starting to build up the intrigue, finally
    Quote Originally Posted by Nighthwk12 View Post
    Correction:..completed Wed night.
  10. #250 Re: Starting to build up the intrigue, finally
    Bill don't **** around people, he gets the **** done.
    If anybody has ever met bill he has arms that could put Barry Bonds to shame LOL
    GTX Level Member crbquist's Avatar
    Massachusetts
    Damn that blows... Hopefully the L36 holds up!
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  12. #252 Re: Starting to build up the intrigue, finally
    It will. I'm going to hide the car from him so he can't blow it up.
  13. #253 Re: Starting to build up the intrigue, finally
    GTP Level Member AjL227's Avatar
    IL
    Time for some E85 this time, help prevent another accident.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
    Massachusetts
    Max + higher compression = a horse of a different color
  15. #255 Re: Starting to build up the intrigue, finally
    May 2012
    CT
    Good stuff Bill. Hopefully it holds up this time. lol
  16. #256 Re: Starting to build up the intrigue, finally
    Feb 2009
    flintnasty MI
    is there any data to back up the failure? Chipping pistons is EXTREMELY hard to do... it takes alot of things going wrong to get those sort of piston temperatures.
  17. #257 Re: Starting to build up the intrigue, finally
    Well..the head came off and the piston was chipped. When you say data to back it up, no recording was being done at the time of the failure.
    Massachusetts
    I thought pistons weren't all that hard chip depending on how much detonation you have. And I remember Max saying he had 0* KR? If he chipped one on his L32, wouldn't his L36 be more vulnerable under the same setup?
  19. #259 Re: Starting to build up the intrigue, finally
    Topeka, KS
    Man i'm sure mine are chipped. I just hope my car holds up until I can start my build.
  20. #260 Re: Starting to build up the intrigue, finally
    Signs of a chipped piston.
    1. Car runs bad, you pull plugs and find one or more electrodes smashed.
    2. Pieces of piston on top of your IC core. They can come up through the bypass hole of the SC
    3. Visual confirmation
    From research and chatting with others, apparently GM didn't gap the rings on the L26 and L32 as much as the predecessor engines. Therefore it's easier to chip a piston.
    Max should be returning from a trip today. Likely we'll hear from him.
  1. 00' Grand Prix GTP (Build starting)
    By Stinkygrub in forum Members Rides
    Last Post: 04-09-2012, 10:48 AM
  2. trouble starting after topswap/build
    By MrClean in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2011, 11:08 PM
  3. Starting the new build soon:)
    By bballa0740 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 09:34 PM
  4. Carbon Build up / hard starting
    By john breit in forum General Tech Discussion
    Last Post: 03-07-2011, 02:46 PM
