View Poll Results: What color should I paint her?
Voters
8. You may not vote on this poll
  • Black
    2 25.00%
  • White
    1 12.50%
  • Orange
    2 25.00%
  • Green
    0 0%
  • Blue
    3 37.50%
Multiple Choice Poll.
Thread: Project Car
Results 1 to 12 of 12
Justinm1700 Project Car 10-14-2015, 02:06 AM
16MustangVet Re: Project Car 10-14-2015, 03:14 AM
BillBoost37 Re: Project Car 10-14-2015, 07:21 AM
04lss Re: Project Car 10-14-2015, 07:23 AM
onenayr92 Re: Project Car 10-14-2015, 08:20 AM
BillBoost37 Re: Project Car 10-14-2015, 08:00 AM
onenayr92 Re: Project Car 10-14-2015, 08:21 AM
Justinm1700 Re: Project Car 10-15-2015, 09:13 PM
04lss Re: Project Car 10-16-2015, 08:58 AM
Justinm1700 Re: Project Car 10-16-2015, 07:44 PM
Fivefingerdeathpunch Re: Project Car 10-17-2015, 12:42 AM
Justinm1700 Re: Project Car 10-17-2015, 10:34 PM
  1. #1 Project Car
    SE Level Member Justinm1700's Avatar
    Oct 2015
    Fargo, ND
    Just bought a 2002 Grand Prix GT for $650 with 155,631 miles. I thought it was a steal, she needs quite a bit of work though ($2500 of work). What are some suggestions of things I should do right away. I need brakes and eberything under the hood is leaking, but it's all still good and the engine is strong.
    Project Car Attached Images
  2. #2 Re: Project Car
    all grand prixs are a project car.............. they all break.
    keep it driveable keep fluids topped off spend money on catastrophic issues not if but when needed ex. transmission.
    fvck the paint job multicolor mechanically sound + race car parts 1st lol.
  3. #3 Re: Project Car
    Needs $2500...that's not a good car. Maybe we can help you save some dinero if you tell us what needs to be fixed up on it.
    Color.. bah
  4. #4 Re: Project Car
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    ^ This, its a GM, itll never have everything right at the same time.
    Careful with valve cover gaskets the OEM ones started fires on some of these cars, if it hasn't been replaced yet, a GM dealer will replace one of them no charge.
    Flush the transmission, spark plugs, check the cooling system make sure its not all goopy from mixing fluids or Dexron decay.
    if you have to do anything like replacing ball joints or hub bearings, go ahead and replace the sway bar end links, new ones firm up the car a little in my experience. They only cost like $10-$20
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  5. #5 Re: Project Car
    SE Level Member onenayr92's Avatar
    May 2014
    Choctaw, OK
    Quote Originally Posted by 04lss View Post
    Id say be careful flushing the transmission fluid with that many miles if it has never been done before. I'd say take a quart out and add some Lucas transmission fluid.
  6. #6 Re: Project Car
    gaskets leak..but they didn't cause the fires. The close proximity exhaust shield is the only thing I see them changing that isn't on every other body style 3800, that no recalls ever happened on.
  7. #7 Re: Project Car
    May 2014
    Choctaw, OK
    I thought it had something to do with the spark plug covers. I had my car recalled and that is all they replaced on mine.
  8. #8 Re: Project Car
    Oct 2015
    Fargo, ND
    Needs a new oil pan, all fluids changed, brakes all the way around, lots more I can't remember at the top of my head. ALSO I need a new drivers side seat as a 600lb person destroyed the support.
    Also one of the rims is cracked, but I have rims to put on it, which I'm super excited about.
  9. #9 Re: Project Car
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by Justinm1700 View Post
    all 3 wbody cars ive owned have had issues with the seats. Let me guess, its on the left side, towards the rear of the seat?
  10. #10 Re: Project Car
    Oct 2015
    Fargo, ND
    Yup haha. I shoved a pillow under it and its fine for now, ha. Never had problems with my 1998 GP GT that I had a few years ago, although that was leather, so maybe its not the same.
    Also having trouble with my headlights not fitting right, is there an easy way to fix this or is it a bumper issue?
  11. #11 Re: Project Car
    They all have gaps for days............. good luck fixing that issue.
    Otherwise make sure both tabs on the headlight bracket go into the metal bracket on the body, otherwise it will fit all goofy.
  12. #12 Re: Project Car
    Oct 2015
    Fargo, ND
    Well yea, theyre in the bracket, but thats exactly why they don't fit right, ha. I feel like I just want to make my own holes in it to fit better.
  1. Replies: 97
    Last Post: 08-08-2017, 08:12 AM
  2. new project 3.1 to 3.8
    By Jtwelding in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-24-2010, 09:45 AM
  3. next project
    By JarenSTi in forum Off Topic Discussion
    Last Post: 01-01-2010, 09:35 PM
  4. my new project
    By 99gpse in forum Off Topic Discussion
    Last Post: 05-11-2009, 12:03 AM
  5. My p&p project is almost done!!!!
    By josh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2009, 09:13 PM
