Thread: cranks but wont start
Results 1 to 11 of 11
  1. #1 cranks but wont start
    Aug 2015
    ohio
    Got 99 Grand prix cranks but wont start. checked ignition spark at the ignition modules or whatever they are called. Got spark from all six wire plugs, am assuming that means crank sensor good? since getting spark. Check fuel pressure 45-50 psi when cranking. Checked compression all around 150. Replaced pcv valve and pressure sensor on top of it. Sounds like it backfires when cranking over at times. Any suggestion on what going on. checked codes not throwing anything to reader.
  2. #2 Re: cranks but wont start
    ever do a tune up? has it been slowly taking a crap on ya? or was it perfect yesterday and dead today?
  3. #3 Re: cranks but wont start
    Aug 2015
    ohio
    Took crap starting to wonder if upper intake
    Is leaking just not enough to hydro lock.
  4. #4 Re: cranks but wont start
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Gboy View Post
    If hydrolocked, there would be no crank.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: cranks but wont start
    Aug 2015
    ohio
    That's why I said not enough to hydrolock
  6. #6 Re: cranks but wont start
    Jul 2010
    Coquitlam,BC,Canada
    My bad. Apparently I didn't read the "not" part. Carry on. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: cranks but wont start
    pull the plugs, see if they are wet with coolant.
  8. #8 Re: cranks but wont start
    Feb 2013
    37.295091, -121.930053
    your plugs are wet either from coolant or fuel. also whats the compression like? what were the last 5 things done to the engine?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: cranks but wont start
    Aug 2015
    ohio
    Ok found coolant in intake so replaced upper and lower intake gaskets. Do I need to replace plugs they aren't that old? Did notice some of plugs were loose. Don't know if it was from extra pressure in cylinders when motor was still running and trying to hydrolock. Still can't get it to start. Everything else looks good. Haven't checked timing yet.
  10. #10 Re: cranks but wont start
    If you pull the TB 3 10mm. Look right in and see if it's soaked
  11. #11 Re: cranks but wont start
    it getting gas? check the rail shrader valve, see if any thing sprays out.
  1. Cranks but won't start
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2013, 03:41 PM
  2. cranks but wont turn over and im stumped
    By swagcaptain in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-11-2013, 06:47 AM
  3. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  4. car cranks but wont start unless you press accelerator
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:49 PM
  5. cranks wont start
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2009, 08:10 PM
