Thread: Need help asap
Results 1 to 17 of 17
  1. #1 Need help asap
    Sep 2015
    Ct
    So I just bought an 04 gtp and I'm driving home from auto parts store, I decided to turn the head lights on, at almost that exact moment, car completely dies and now won't do anything. Feels Like a dead battery, but there was no warning like dimming lights. I'm thinking maybe a short somewhere. So random that it died when I turned on the headlights.
    Any ideas, please and thanks
  2. #2 Re: Need help asap
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    i would check fuses, battery connections, grounds.
  3. #3 Re: Need help asap
    bad ground could be the issue, you guys got a screwy neg cable connection on the 04 ups dont you?
  4. #4 Re: Need help asap
    Sep 2015
    Ct
    Also just noticed that the red alarm light is solid on. Possibly some weird kill switch in the headlight switch?
  5. #5 Re: Need help asap
    May 2011
    Illinois
    no weird kill switch, but sometimes multi function switches do go bad.
  6. #6 Re: Need help asap
    Sep 2015
    Ct
    Could you explain the multi function switch and could that cause the car to completely die?
  7. #7 Re: Need help asap
    hows a multi switch gonna not let it have power?
    is the car not cranking? do the dash lights light up when the key is turned to run? hear a click when you turn the key to start?
    more info please.
  8. #8 Re: Need help asap
    Sep 2015
    Ct
    Absolutely nothing, no lights, no sounds, the gauges are also stuck where they were at web car was running. Battery is good. Just tried jumping it and still no lights or sounds with cables hooked up
  9. #9 Re: Need help asap
    thats truly dead. and very odd.
    make sure the battery cables are all connected well. on the starter, and the driver side bell housing is the ground cable. as well as the battery.
    that 04 up neg cable to battery keeps coming to mind, as its a pos. some dumb clamp set up iirc.
  10. #10 Re: Need help asap
    Sep 2015
    Ct
    The cable looks solid and fairly clean. Is there any fuses or anything that would deny power to the whole car.
  11. #11 Re: Need help asap
    Sep 2015
    Ct
    update, when the car got put on the tow truck, the hazard lights came on and stayed on through out the 15 min drive. Then, when the truck dropped my car off at my house, I can't get the lights to come back on. I cleaned the cable from the battery to the support bar near the fuze box, and i checked the grounds on the front of the motor. Still nothing. I get sparks and i hear electrical things clicking when i disconnect, then reconnect a ground, but no sign of life afterwords. Any other ideas or more grounds.
  12. #12 Re: Need help asap
    Sep 2015
    Ct
    update!! So the ground wire on pass side, from neg terminal to brace seems to be the culprit. Originally the ground was on top of the brace, i then moved it underneath and the all power was restored. Now my only issue is the DIC says inspect theft system or something like that. Thoughts?
  13. #13 Re: Need help asap
    drive it and see if it goes away. if it dont after a day or so un hook the neg cable for 30 minutes or more, this should reset the cars systems. and hopefully clear its self.
  14. #14 Re: Need help asap
    Sep 2015
    Ct
    Thanks for your help. Now onto my original issue of cylinder 3 misfire
  15. #15 Re: Need help asap
    Feb 2013
    37.295091, -121.930053
    if your having a misfire in cylinder 3 or 4 it most likely is a chipped piston
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  16. #16 Re: Need help asap
    pull the plug out, look at it.
    its the middle rad side plug.
  17. #17 Re: Need help asap
    Why would that be the most likely problem?
    There are SO MANY other things that could cause it. A bad plug, bad wire, a bad coil, a bad ICM, faulty injector, massive vacuum leak. Chipped piston is normally the last thing I think of on random misfires.
  1. Need Help ASAP
    By Grimsin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-17-2012, 10:34 AM
  2. What is this and where do it get it ASAP!!!
    By chevyy1212 in forum General Tech Discussion
    Last Post: 07-27-2011, 06:13 PM
  3. New Here, needs help asap
    By holt149 in forum Introductions/Noob Questions
    Last Post: 02-20-2011, 08:01 PM
  4. 8 rib help! asap please!
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2009, 05:40 PM
  5. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
