Thread: Need Help ASAP
Results 1 to 20 of 22
  1. #1 Need Help ASAP
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I have a friend that lost 4th gear.
    2000 bonneville SSEI is the car.
    He wanted me to ask if the TCC solinoid is interchangeable from gtps, impala, etc etc, anyone have a exact list of what cars?
    I am no expert, but is that why he lost 4th gear?
    thanks all
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  2. #2 Re: Need Help ASAP
    He doesn't have a hardened 4th gear shaft and it stripped that's why he lost 4th. He needs a new shaft.
  3. #3 Re: Need Help ASAP
    St Thomas Ontario
    to fix that does he need the tranny completly out of the car?, does it need a whole rebuild or does it just need the new shaft?
    thx we were gonna have a race in a few days. but then tranny did this..lol
  4. #4 Re: Need Help ASAP
    He can still drive it the way it is just do a pan drop and filter change. You don't have to drop the trans out to change it. I believe you can pull the side cover and change it that way but I'm not sure.
  5. #5 Re: Need Help ASAP
    St Thomas Ontario
    will a tranny from a supercharged regal go into his bonnie?
  6. #6 Re: Need Help ASAP
    Mar 2012
    NC
    It should go right in. I believe the SSEI used the same ratio as the Regal GS.
  7. #7 Re: Need Help ASAP
    St Thomas Ontario
    same as gtp's correct?
    Mercer, Pa
    What year ssei? The tranny mounts are different and its actually a different tranny housing. You don't have to pull tranny to replace but you do have to lower engine and tranny down a long way so you can get the pan off.
    Contact tripleedgeperformance for specific details.
  9. #9 Re: Need Help ASAP
    first post
  10. #10 Re: Need Help ASAP
    St Thomas Ontario
    any other guru's give more info? he is gonna load the bonne and move to b.c(across canada) soon so need it running in good shape.
  11. #11 Re: Need Help ASAP
    Just get a trans out of a sc h body and he'll be set. Same gear ratio same mounts.
    Mercer, Pa
  13. #13 Re: Need Help ASAP
    Here is a hot to fix it. http://www.grandprixforums.net/how-t...ess-54448.html
    A replacement trans doesn't have to come from an H body. H, C, and G all had the same rear type of trans mount. Also the gearing as long as it's an HD trans is all the same on the 4T65E. What you need to know if you buy a trans to swap it is that is looks like this on the back.
    This is what you will commonly find in a W body, because it has no rear mount to bolt to the casing. Although many W bodies have cases that have the extra support/bolt holes in back.
  14. #14 Re: Need Help ASAP
    St Thomas Ontario
    Thankyou Bill!
  15. #15 Re: Need Help ASAP
    NP guy.. half the battle is often learning that the write up exists.
  16. #16 Re: Need Help ASAP
    St Thomas Ontario
    so apparently there were 3 different transmission in the 2000 Bonneville ssei's
    model #'s
    FCB
    CHB
    FHB
    I cant fin the Letters anywhere on the tranny..... Bill do you know where you would find it?
  17. #17 Re: Need Help ASAP
    Banned
    Sioux Falls, SD
    It might be on the metal tag on the trans i might be wrong
  18. #18 Re: Need Help ASAP
    It's on the right side see the purply thing
    Transmissions
    That's the tag. FWIW though..you can swap any of the ones in there.
  19. #19 Re: Need Help ASAP
    St Thomas Ontario
    where is the air compressor for the rear air ride shocks located? 2000 Bonneville ssei any info would be greatly appreciated
  20. #20 Re: Need Help ASAP
    Should be under one of the rear quarters. Although I'm not 100% on it's exact. The leveling switch is on the driverside strut..just inside the wheel well. Often those go bad.
  1. Need help asap
    By Stinkygrub in forum Engine
    Last Post: 07-20-2021, 09:17 PM
  2. Need Help ASAP! Please.
    By Grand PrE in forum Off Topic Discussion
    Last Post: 06-03-2011, 02:04 PM
  3. 8 rib help! asap please!
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2009, 05:40 PM
  4. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
