Thread: Car issues couple of fault codes.
Results 1 to 5 of 5
  1. #1 Car issues couple of fault codes.
    SE Level Member wakkamis's Avatar
    Jun 2013
    elgin
    I was following along on another thread where a vehicle was overheating, did the flush and fill and bleed out the air, and I'm still having issues. The engine started doing what i can only describe as a hiccup. Happens a few times a trip while accelerating or idling or stopped at a light.
    I picked up an obd 2 bluetooth reader and the torque app for android and saved these logs out:
    Any info would be awesome, Thanks!
    (I do not know why its throwing color tags around everything. :/)
    Fault log report generated by Torque for Android
    Vehicle VIN:
    [COLOR=rgba(0, 0, 0, 0.8)]Vehicle Manufacturer:
    [COLOR=rgba(0, 0, 0, 0.8)]Vehicle Calibration ID:
    [COLOR=rgba(0, 0, 0, 0.8)]Current Fault Log
    [COLOR=rgba(0, 0, 0, 0.8)]------------------
    [COLOR=rgba(0, 0, 0, 0.8)]P0171: System too Lean (Bank 1)
    [COLOR=rgba(0, 0, 0, 0.8)]P0481: Cooling Fan 2 Control Circuit
    [COLOR=rgba(0, 0, 0, 0.8)]Pending Fault Log
    [COLOR=rgba(0, 0, 0, 0.8)]ECU reports no pending faults
    [COLOR=rgba(0, 0, 0, 0.8)]Historic Fault Log
    [COLOR=rgba(0, 0, 0, 0.8)]ECU reports no historic faults
    [COLOR=rgba(0, 0, 0, 0.8)]Other discovered fault codes
    [COLOR=rgba(0, 0, 0, 0.8)](possibly pending, current or manufacturer specific)
    [COLOR=rgba(0, 0, 0, 0.8)]----------------------------------------------------
    [COLOR=rgba(0, 0, 0, 0.8)]ECU reports no other fault codes logged
    [COLOR=rgba(0, 0, 0, 0.8)]End of report.
    and
    [/COLOR][COLOR=rgba(0, 0, 0, 0.8)]Mode $06 report generated by Torque for Android
    [COLOR=rgba(0, 0, 0, 0.8)]================================================
    [COLOR=rgba(0, 0, 0, 0.8)]Vehicle VIN:
    [COLOR=rgba(0, 0, 0, 0.8)]Unit and scaling information are not supplied with the data from the ECU for this type of vehicle. Consulting the manufacturers service book for this information is recommended.
    [COLOR=rgba(0, 0, 0, 0.8)]Test report:
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$01
    [COLOR=rgba(0, 0, 0, 0.8)] - Rich to Lean sensor switch time(calculated)
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 65,535
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 14,400
    [COLOR=rgba(0, 0, 0, 0.8)]PASS
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$02
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 15,999[
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$03
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 9,583
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$04
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 17,638
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$05
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 10,880
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 1,792
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$06
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 10,240
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 896
    [COLOR=rgba(0, 0, 0, 0.8)]----[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$07
    [COLOR=rgba(0, 0, 0, 0.8)]Min: 42
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 230
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$08
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 231
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0a
    [COLOR=rgba(0, 0, 0, 0.8)]Test incomplete or dependant test failed
    [COLOR=rgba(0, 0, 0, 0.8)]--[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0b[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)] - Rich to Lean sensor switch time(calculated)[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Min: 21,944[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 15,694[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]FAIL[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0c[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 9,305[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 13,888[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0d[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 32,903 Min: 32,738[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 32,782[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]PASS[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$07 CID:$4f[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)] - Minimum sensor Voltage for test cycle(calculated)[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 33,564[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 31,023[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$01[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)] - Sensor period(calculated)[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 150[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 16[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$04[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Min: 50[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 50[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$05[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 289[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 53[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$06[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 123[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 31[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$07[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Min: 600[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 600[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$42[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Min: 6,000[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 6,039[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0a CID:$48[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 32,868[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 32,770[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0c CID:$60[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)] - Misfire counts for last/current driving cycles(calculated)[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 32,768[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 32,768[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$0e CID:$12[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)] - [/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 0[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 418[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$01[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 65,535[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 14,400[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$02[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 15,999[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$03[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 9,583[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$04[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 17,638[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$05[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 10,880[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 1,792[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$06[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Max: 10,240[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 896[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$07[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Min: 42[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 230[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$08[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test result value: 231[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]TID:$05 CID:$0a[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]Test incomplete or dependant test failed[/COLOR]
    [COLOR=rgba(0, 0, 0, 0.8)]End of report.[/COLOR]
  2. #2 Re: Car issues couple of fault codes.
    you need to redo them pic's if thats what they were. no idea what any of that means.
  3. #3 Re: Car issues couple of fault codes.
    I see a 171 in there
  4. #4 Re: Car issues couple of fault codes.
    Jun 2013
    elgin
    not supposed to be pics.. just a log from torque...
    mostly intrested in:
  5. #5 Re: Car issues couple of fault codes.
    My fix for hiccups is a crank sensor swap. First time I came across the sensor was my car doing a hiccup. Here's the way to ensure if it's a crank sensor... watch your run time counter. If it reset during your trip, it's a crank sensor.
  1. 2008Grand prix fault codes p1125-p2120-p2138
    By daviddawg in forum Introductions/Noob Questions
    Last Post: 04-04-2014, 02:10 PM
  2. '06 2 Throttle Fault Codes
    By Subwarrior632 in forum General Tech Discussion
    Last Post: 10-22-2012, 12:01 PM
  3. 3 Transmission fault codes
    By JB381 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-29-2010, 09:38 PM
  4. Pls help with fault codes
    By stoksuks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2010, 06:15 PM
  5. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
