Thread: Flexible Transmission Dipstick
Results 1 to 15 of 15
  1. #1 Flexible Transmission Dipstick
    May 2015
    Joliet, Illinois 60436
    Could someone recommend a flexible trans dipstick?
  2. #2 Re: Flexible Transmission Dipstick
    Feb 2013
    37.295091, -121.930053
    yeah the stock one. why you ask simple its give you the correct level if you put in an aftermarket one then the level will be way off
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Flexible Transmission Dipstick
    May 2015
    Do you happen to have a photo of a stock bent dipstick?
  4. #4 Re: Flexible Transmission Dipstick
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    This is something to be asked in chat or something. This shouldn't be a whole thread.
  5. #5 Re: Flexible Transmission Dipstick
    Feb 2013
  6. #6 Re: Flexible Transmission Dipstick
    GXP Level Member
    Mar 2015
    Tomball
    www. go to the junkyard .com it'll take you all of 5 minutes and you won't even need any tools.
  7. #7 Re: Flexible Transmission Dipstick
    Kemmerer, Wyoming
    I have a flexible transmission dipstick tube, it came with the transmission I bought, so I couldn't say where you could get one. reading the transmission fluid level is pretty tough on that dipstick, not sure if I would recommend one.
  8. #8 Re: Flexible Transmission Dipstick
    Apr 2015
    Isn't he looking for a transmission dipstick?
  9. #9 Re: Flexible Transmission Dipstick
    Feb 2013
    yes but at least he can look on ebay for it
  10. #10 Re: Flexible Transmission Dipstick
    Apr 2015
    True.
  11. #11 Re: Flexible Transmission Dipstick
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Srs?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  12. #12 Re: Flexible Transmission Dipstick
    GXP Level Member
    Mar 2015
    Tomball
    Unless you compare them you won't know.
  13. #13 Re: Flexible Transmission Dipstick
    Nov 2011
    NY
    Quote Originally Posted by snj111795 View Post
    A few pertinent things left out...
    make, model, year...
    why hy do you think you need a flexible aftermarket transmission dipstick?
  14. #14 Re: Flexible Transmission Dipstick
    tube from my 98 regal fit, only bent it maybe a 1/2 inch off the crossover.
  15. #15 Re: Flexible Transmission Dipstick
    hangover park IL
    std lokar 4l60e dipstick setup, and YES you can shorten the teflon dipstick section at the handle to the length you need.
    yes its a ********** to fill and read but it sits about 3-6" away from 1200* exhaust.
    to make the level reading easier you need to rough up the glossy extruded teflon dipstick with some scotchbrite/etc.
    the molded in crosshatch area is too glossy to hold a visible amount of fluid....
    ~James~ Psychotic Gearhead
  1. Transmission dipstick obsolete at GM dealer?
    By PeezDaddy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2013, 10:33 PM
  2. Is it normal to have bubbles on the transmission dipstick?
    By Coldwaves in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2013, 10:16 PM
  3. Where can I find a flexible trans dipstick?
    By PokerBlakeB in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2012, 06:31 AM
  4. Are the flexible dipsticks accurate out of the box?
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-07-2008, 11:13 PM
