Thread: Removing stuck O2
Results 1 to 7 of 7
  1. #1 Removing stuck O2
    May 2015
    Joliet, Illinois 60436
    I'm trying to remove my O2 sensors from my rear manifold and downpipe and transfer them to my headers. But as I'm sure you know these things are really stuck in there. Is this more headache than it's worth?
  2. #2 Re: Removing stuck O2
    buy a new o2. mine never came out. rusted solid in there, i tried to get it off in the car and no dice, off the car i stripped the nut out.
  3. #3 Re: Removing stuck O2
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    They're not that bad to get off. Just use the correct O2 sensor socket and some PB blaster or what not. Everyone I've done came right out without any issue.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  4. #4 Re: Removing stuck O2
    i had the right socket, it stripped the nut on the sensor. a lot of guys never get it out unless you heat the piss out of it.
  5. #5 Re: Removing stuck O2
    Buffalo
    Had this issue recently with my wideband. That sucker was in there solid. I was wondering if I was going to the break the welds on the o2 bung. Heat and breaker bar
  6. #6 Re: Removing stuck O2
    I have taken them out with the car running to keep things heated up.
  7. #7 Re: Removing stuck O2
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    Quote Originally Posted by ScottyDoggs View Post
    what he said
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  1. Removing A/C condensor without removing radiator?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-02-2014, 07:43 AM
  2. key stuck and shifter button stuck 50% of the time
    By brugg125er in forum General Tech Discussion
    Last Post: 03-21-2014, 10:21 AM
  3. help: removing a stuck oil drain plug
    By orange57 in forum General Tech Discussion
    Last Post: 07-13-2013, 05:34 PM
  4. Finished removing the stuck gasket, whatcha' ya think?
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 07-31-2012, 10:41 PM
  5. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
