Thread: key stuck and shifter button stuck 50% of the time
Results 1 to 6 of 6
  1. #1 key stuck and shifter button stuck 50% of the time
    Feb 2014
    Grand Forks, North Dakota
    So sometimes when I shut my car off the key won't turn all the way to where i can take it out of the ignition. Plus when I step on the brake to shift into gear I don't hear the "click" to unlock my button on the shifter. Are these two things connected, key stuck in ignition and shifter not unlocking? And how would I go about fixing it? I pulled out the little shift lock tab next to the shifter to see if it would do anything and it did not.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  2. #2 Re: key stuck and shifter button stuck 50% of the time
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    there are some wires under the center console near the shifter that can break and not cause they key to be released. I forget the specific name for the thing. But under the wheel is a little round cover you can pop off then shove a small screw driver up and it frees the ignition. mines does it every so often.
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: key stuck and shifter button stuck 50% of the time
    Grand Rapids, MI
    you can actually tilt the wheel all the way up and press the button with your hand to release your key. to solve that problem, zip tie the button down or remove the solenoid all together.
  4. #4 Re: key stuck and shifter button stuck 50% of the time
    Feb 2014
    aha. thanks guys. I actually noticed for when trying to unlock the button to shift, I have to push the little spring loaded button under the shift lock tab down somewhat far or until it bottoms out. But I guess for now ill just keep a screwdriver in my center console. lol
  5. #5 Re: key stuck and shifter button stuck 50% of the time
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: key stuck and shifter button stuck 50% of the time
    you can take a straw, cut it to size put it in the hole, then put that cap back on. this will keep the button pushed up till you get the wires in the console fixed up.
  1. 2002 GP GT shifter stuck in park.
    By danford1 in forum Introductions/Noob Questions
    Last Post: 08-24-2013, 07:48 PM
  2. Key Stuck in Ignition and Shifter Stuck in Park
    By GRAFIX in forum General Tech Discussion
    Last Post: 02-25-2012, 02:50 PM
  3. Stuck in park! Cant push shifter button!
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 04-05-2011, 09:23 AM
  4. Key stuck in ignition & shifter wont release!!
    By Pontiac 2003 in forum General Tech Discussion
    Last Post: 04-03-2010, 12:54 PM
  5. Shifter button stuck?? Cant remove key
    By PRIXSY in forum General Tech Discussion
    Last Post: 02-25-2009, 07:45 PM
