Thread: Power Steering Noises and Indicator Lights
Results 1 to 2 of 2
  1. #1 Re: Power Steering Noises and Indicator Lights
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    a bad wheel hub assembly will set off the abs / TC lights. the wheel speed sensors are built into the hub assembly . could also be just the wire harness that connects into the speed sensor. go to autozone or advanced auto and get them to pull the codes for you . then try unplugging them and cleaning the connectors with electronic cleaner. if that doesn't help check the resistance at the wire harness with a multimeter and if they aren't reading close to the same then you know it's in the harness. if they give a good reading then it's the speed sensor itself and you'll have to replace the hub assembly. here's a helpful video showing you how. CHECK YOUR BRAKE FLUID. make sure it's at the proper level .
    if a scan tool won't pull the codes then you're probably looking at a bad ECBM.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  1. Loud groaning noises from steering system
    By jpearsall187 in forum General Tech Discussion
    Last Post: 12-08-2013, 01:47 PM
  2. No power after shifting and weird noises
    By Monroe8822 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2013, 10:22 PM
  3. Power steering noises.
    By Justin48 in forum General Tech Discussion
    Last Post: 02-05-2013, 01:27 AM
  4. Ac, Ac max power and rear defroster indicator lights are blinking
    By gto421 in forum General Tech Discussion
    Last Post: 09-21-2012, 12:43 AM
  5. 2004 GP GTP – steering anomalies/noises
    By manny47 in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2010, 04:09 PM
