Thread: code p0171 system too lean need help ASAP please!
Results 1 to 2 of 2
  1. #1 code p0171 system too lean need help ASAP please!
    Apr 2015
    connecticut
    so this code is the only one on and I have emissions tomorrow and I have been trying and changing everything. So I changed the upper plenum and lower intake manifold gasket, new pcv valve, new map and maf sensor, it said system too lean bank 1 so I change 02 sensor bank 1 but that didn't work and I am afraid to use carb cleaner because I don't know exactly where to spray it to check the vacuum line. Anyone have any idea what it could be I guess I'm going to have to suck it up and spray but any other suggestions?
  2. #2 Re: code p0171 system too lean need help ASAP please!
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    my guess is vacuum leak. Assuming you have a gtp, here is the diagram for the vacuum lines. http://www.justanswer.com/pontiac/3c...-prix-gtp.html
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  1. P0171 Front Bank Lean
    By Wolf79 in forum General Tech Discussion
    Last Post: 05-15-2014, 12:50 AM
  2. Codes P0171 Lean Bank One
    By Garry in forum General Tech Discussion
    Last Post: 02-07-2013, 05:10 PM
  3. fixed the p0171 lean condition
    By Erik Adam Rodriguez in forum General Tech Discussion
    Last Post: 01-27-2013, 10:00 PM
  4. P0171 - System Too Lean (Bank 1)
    By siege101 in forum General Tech Discussion
    Last Post: 04-28-2012, 07:48 PM
  5. Fuel system to lean???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 02-05-2011, 02:51 PM
