Thread: Fuel system to lean???
Results 1 to 17 of 17
  1. #1 Fuel system to lean???
    Alabama
    I have a ? for you guys. The diagnostic machine says fuel system to lean. I already replaced the 02 sensor, plugs and wires and fuel filter. My next assumption is either bad injectors or weak fuel pump. My question for you guys is how can i distinguish which one? Those parts are a bit pricey to buy one and that not be the problem. Thanks in advance.
    Black Grand Prix GT Gold Edition. headers, K&N air filter, catless exhaust, 2 Legacy Comp 15's pushed by 2500 watt Power Accoustik amp. Wish there was more but I'm baaallllin on a budget!
  2. #2 Re: Fuel system to lean???
  3. #3 Re: Fuel system to lean???
    what are 4:2:1 headers?
  4. #4 Re: Fuel system to lean???
    Alabama
    Come to think of it I crunk the car up while I was under the hood and I could hear air blowing. Could that be why?
  5. #5 Re: Fuel system to lean???
    Air blowing is more likely the fans.
    vacuum leak sounds more like hissing.
  6. #6 Re: Fuel system to lean???
    Alabama
    No it wasn't the fan, it was kind of a hissing sound but wouldn't that be caused by an air leakage?
  7. #7 Re: Fuel system to lean???
    likely an air leak if it was hissing.
    Was this when the car was warmed up?
    If so, i'd break out the carb cleaner and spray around and listen for any change in engine speed.
  8. #8 Re: Fuel system to lean???
    Your code is P0171
    Google will find you the fsm pages on it which will suggest maf or vacuum leak. I've found a few other things including vacuum leak to be the most common. Lemme see if I can find that good post I think I did here.
  9. #9 Re: Fuel system to lean???
    Jan 1970
    Maquoketa, Iowa
    Look around the throttle body for cracked hoses or loose hoses, as well as under the s/c snout, there is a T fitting going into the lower intake. If u can hear the hiss u should be able to trace the leak. Unmetered air entering the engine would make it run lean and throw that code.
  10. #10 Re: Fuel system to lean???
    Alabama
    Yea the car was pretty warm when I checked. Where do I spray the carb cleaner?
  11. #11 Re: Fuel system to lean???
    Heer ya go
    I've found P0171 to be a few different things.
    Evap backwards: Luckily the W bodies were redesigned and didn't get the same crappy hookups to the evap system as the H bodies. However it's possible the evap hoses at the soleniod were mixed up during work.
    Corroded battery cables: If the corrosion is bad enough, it'll mess with the voltages a bit and throw the code.
    Vacuum leaks: A very common leak is the EGR tube that leads from the EGR to the LIM. It's nearly impossible to spray with cleaner and get a reaction. Yet if you pull it and look where the piece that holds it to the LIM sits...you'll usually find a crack in it.
  12. #12 Re: Fuel system to lean???
    Just saying..
    Can't tell you the number of times I've fixed this code by checking the tube.
  13. #13 Re: Fuel system to lean???
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    x2 vac leak
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  14. #14 Re: Fuel system to lean???
    Alabama
    Thank all you guys. I've been racking my brain and spending way too much cash for a what seemed like a simple issue. So if I spray carb cleaner in what type of change should I be looking for at idle? I know I probably sound dumb right now lol but this seems so simple it's difficult...
  15. #15 Re: Fuel system to lean???
    Alabama
    Also will a vacuum leak make the car run horrible when you gas it hard?
  16. #16 Re: Fuel system to lean???
    http://www.grandprixforums.net/vaccum_leaks.php
    Big enough vac leak will kill the car. Thats how bad they are for the engine
  17. #17 Re: Fuel system to lean???
    I love that tube... Broke a few myself.... and yeah, spray doesnt affect engine speed when its broken.
  1. P0171 - System Too Lean (Bank 1)
    By siege101 in forum General Tech Discussion
    Last Post: 04-28-2012, 07:48 PM
  2. fuel system?
    By iluvbst in forum General Tech Discussion
    Last Post: 09-22-2010, 09:09 PM
  3. My new fuel system...
    By Hellfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2009, 10:37 PM
  4. Fuel System
    By joesforspeed in forum Turbo
    Last Post: 02-04-2009, 12:38 PM
