Thread: Engine dies while driving?
Results 1 to 6 of 6
AZGPrix Engine dies while driving? 03-23-2015, 12:23 PM
02NavyBlue Re: Engine dies while driving? 03-23-2015, 02:05 PM
Seachicken Re: Engine dies while driving? 03-24-2015, 09:14 PM
AZGPrix Re: Engine dies while driving? 03-26-2015, 01:53 PM
Seachicken Re: Engine dies while driving? 03-26-2015, 09:15 PM
blueguy Re: Engine dies while driving? 03-26-2015, 01:55 PM
  1. #1 Engine dies while driving?
    Mar 2015
    Phoenix
    Hi my name is Curtis. I am new to this forum. I recently purchased an 03 Grand Prix V6 3.1L. The vehicle has over 200,000 miles but runs very good, well it did. My vehicle has been dying on me while I am driving. The firs time this happened I was making a right turn at a street light when my car died, I coasted into a parking spot and could not get the car to start. The battery had a full charge and car cranked but no start. I towed my car home that night. The next day I tried again and the darn thing started. Don't know how but it started, so I drove to the corner store and back and had no problems starting.
    A few days ago my wife was running errands and was on her way home when the car died again. She stalled and had some good Samaritans help push vehicle into a gas station parking lot. She called and I was less that 5 minutes away. By the time I got there she said the car started so I followed her back home.
    So I get the car back home and I am thinking the fuel filter is clogged or the fuel pump is going out. So I check for fuel pressure under the hood at the fuel line. Now I don't have the tools to check the system properly. Long story short I have replaced the fuel filter and fuel pump and have the same results. My car still stalls when it heats up it seams. I don't want to guess at what is wrong or replace anymore parts that may not need to be replaced so if anyone has any suggestions or advise I would appreciate your input. Thank you.
  2. #2 Re: Engine dies while driving?
    Dec 2012
    Where 4T65E's were born
    Most likely a cam/crank sensor issue. They always cause it to stall, but work once its cooled off a bit. I'm pretty sure the 3.1 is known for both to go bad but I'm not sure. I'm not a 3.1 guy, most have 3800's but maybe someone will stop by that knows more about them.
    Sold.
  3. #3 Re: Engine dies while driving?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    x2 on crank sensor, Also when it "stalls" does it sputter or does it turn off like a light switch.
    fuel pump relay?
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  4. #4 Re: Engine dies while driving?
    Mar 2015
    Phoenix
    The car does not sputter but I can tell that the vehicle will cut off before it actually stalls. It just stalls. I was told that it may be the ignition module or maybe the ignition switch. I am having an issue with automatic headlights and heater control unit. Key comes out of ignition switch with car on, key is a little worn. Have not checked fuel pump relay. Is there any way I can test the fuel pump relay?
  5. #5 Re: Engine dies while driving?
    Jan 2013
    Edmonton, Alberta
    Quote Originally Posted by AZGPrix View Post
    Are you saying you lose power to the entire car when it has a fit?
    When a car sputters berfore it stalls, I usually look toward fuel first. If it has "fast stall" usually means you lost spark. Could be a few things, ignition switch, bad pcm, ignition module, crank/cam signal lost, bad connector somewhere.
  6. #6 Re: Engine dies while driving?
    I know bending the 85 tab on the GTP's normally sets the fuel pump in high mode and it rules that out...
    Not sure about a 3.1 though.
  1. 98 GTP dies when driving
    By littlerobinson75 in forum General Tech Discussion
    Last Post: 06-27-2014, 10:49 PM
  2. Car dies while driving
    By ajoliver2010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2013, 04:13 PM
  3. 99 GTP Hesitates / Dies while driving
    By tomc in forum Introductions/Noob Questions
    Last Post: 01-25-2013, 07:36 AM
  4. engine dies driving down road
    By mbrann62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-21-2012, 12:05 PM
  5. Driving on express way at 65 mph, engine dies! What the???
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2009, 03:10 PM
