The car does not sputter but I can tell that the vehicle will cut off before it actually stalls. It just stalls. I was told that it may be the ignition module or maybe the ignition switch. I am having an issue with automatic headlights and heater control unit. Key comes out of ignition switch with car on, key is a little worn. Have not checked fuel pump relay. Is there any way I can test the fuel pump relay?
