Thread: engine noise through speaker's
Results 1 to 20 of 34
  1. #1 engine noise through speaker's
    Jan 2015
    Charleston south Carolina
    I have a issue to wear my engine noise comes through my subs how do i fix that problem ive already had a ground loop isolatior hook up but it didnt solve the problem what else can cause that
  2. #2 Re: engine noise through speaker's
    bad ground will do this.
  3. #3 Re: engine noise through speaker's
    GTP Level Member speed demon's Avatar
    Apr 2011
    MICHIGAN
    Better ground,also try grounding the deck.
    '01 GTP: Rebuilt Trans by Andrew S....300m,hardened 4th,Transgo shift kit,V8 chain ect ect,3.8 MPS,ZZP 10.5.....More to come!
  4. #4 Re: engine noise through speaker's
    Jan 2015
    So should i rewire everything
  5. #5 Re: engine noise through speaker's
    not sure where the amp is grounded but you should take the paint off then bolt it down. if thats been done you may need to find a better spot.
  6. #6 Re: engine noise through speaker's
    Jul 2012
    Chicago
    -Carl
  7. #7 Re: engine noise through speaker's
    Jan 2015
    Alright i will try that and another question im thinking about superchargering my 04 grand prix gt is there anything i need to change out when bolting on the supercharger like new injectors etc
  8. #8 Re: engine noise through speaker's
    yeah, like the rest of the top of the engine. its called a top swap. you use sc heads, lim, blower balancer, pulleys for the sc, fuel rail and injectors. and you want to add headers and a tune.
    just a few things.
  9. #9 Re: engine noise through speaker's
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    Yep youd need to swap heads injectors etc. n/a engine isnt designed to have a SC slapped on it. Cant handle all of the boost. Plus its better to have a lower compression to account for the boost. Its not as easy as slapping a SC like most people think it is. More to it than just that.
  10. #10 Re: engine noise through speaker's
    who told ya it cant handle boost? people turbo them as is.
  11. #11 Re: engine noise through speaker's
    Sep 2014
    U.S.A
    If you put a supercharger on a v8 mustang, once you go past a certain rpm your motor will blow yes theyre different cars but the same principle
  12. #12 Re: engine noise through speaker's
    Jul 2012
    Chicago
    Um... No.
    -Carl
  13. #13 Re: engine noise through speaker's
    Sep 2014
    U.S.A
    Um yeah. Not saying s GP will but it won't like it. Otherwise they wouldnt change anything
  14. #14 Re: engine noise through speaker's
    Jan 2015
    Alright so i was looking online for some headers and i saw some hookers super competition universal headers would that fit my grand prix
  15. #15 Re: engine noise through speaker's
    Quote Originally Posted by Pontiac Racer View Post
    get off the ford forums lol
  16. #16 Re: engine noise through speaker's
    Quote Originally Posted by roddyamazing View Post
    go on ebay look up speed daddy headers for your car. 217 shipped most of the time. cheap and they fit/work. what most of us run.
  17. #17 Re: engine noise through speaker's
    Jul 2012
    Chicago
    Go read up on how cars work.
    Listen to Scotty, SDs are the way to go. Cheap and decent.
    -Carl
  18. #18 Re: engine noise through speaker's
    Jan 2015
    So i just looked up on ebay for the speed daddy headers and i didnt see any for my car well my year
  19. #19 Re: engine noise through speaker's
    you didnt look hard enough....your welcome . http://www.ebay.com/itm/STAINLESS-SS...8dc2e4&vxp=mtr
  20. #20 Re: engine noise through speaker's
    Donating Users timboku's Avatar
    Montgomery, IL
    Crap, I just bought a n/a motor to put in my gtp. Its not gonna like it when I slap l67 heads and a gen v on it?
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. 3.8 Engine Noise
    By bowtienut in forum Engine
    Last Post: 08-18-2014, 06:10 PM
  2. 2002 broken back speaker cover - Bose 4 speaker deck
    By fmp3 in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2013, 06:10 PM
  3. engine noise
    By carlover89 in forum General Tech Discussion
    Last Post: 01-04-2012, 03:31 PM
  4. Monsoon System - What ohm speaker do I need for the center dash speaker?
    By Schmitty in forum Audio, Security & Visual Electronics
    Last Post: 12-22-2011, 07:01 AM
