Thread: OK! Whats better for PCM tune?
Results 1 to 20 of 23
  1. #1 OK! Whats better for PCM tune?
    SE Level Member Goldenrocket06's Avatar
    Jan 2015
    Minnesota
    So just started looking for a tuned pcm and ive personally come across 3 different types that sorta tripped my trigger.. zzp 1.0 PCM, an Overkill PCM or an Intense.. Ive read on different Grand Prix and 3800 forums and all of them say that x brand is better but y brand has this over z brand.. i just cant really make out the TRUE differences in what each pcm is and all that.. Ive got an 06 gp gt.. also heard that with some tunes that the fuel gauge will be backwards..
  2. #2 Re: OK! Whats better for PCM tune?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Overkill ftw. He can also make the fuel gadge work correctly
  3. #3 Re: OK! Whats better for PCM tune?
    Feb 2009
    flintnasty MI
    Know what you are buying and why you are buying it. There is not as mu h "hidden horsepower" in the 3800 pcms like you might find in a ls car.
  4. #4 Re: OK! Whats better for PCM tune?
    Jul 2012
    Chicago
    Overkill, great guy. Your fuel gauge will continue working as it should.
    Have an Overkill tune myself.
    -Carl
  5. #5 Re: OK! Whats better for PCM tune?
    Jan 2015
    Minnesota
    Have you been satisfied with your overkill nos?
  6. #6 Re: OK! Whats better for PCM tune?
    Jul 2012
    Chicago
    My car is NA, so it's not a fair comparison. But he did an 87 and 93 octane tune for me. Cars feels spunkier for sure, maybe not a lot faster, but again that's the down fall of the NA motor. However, the best part was a small increase in fuel economy, and much better transmission operation.
    -Carl
  7. #7 Re: OK! Whats better for PCM tune?
    Jan 2015
    Minnesota
    Sweet.. what were you getting for mpg before and now? i know its N/A but just for a little comparison..
  8. #8 Re: OK! Whats better for PCM tune?
    Jul 2012
    Chicago
    17-20 city, depends on traffic/temperature.
    30+ highway, easily. Unless I do like 85. Seen mid 30s when cruising at 55.
    -Carl
  9. #9 Re: OK! Whats better for PCM tune?
    Jan 2015
    Minnesota
    Sweet! was just lookin to see if it was really worth the upfront cost vs. actual results.. thanks
  10. #10 Re: OK! Whats better for PCM tune?
    Enfield, CT
    I have an overkill myself and I'm enjoying it. I like the transmission behavior and the increase in MPG. The increase in MPG alone will pay for the tune
  11. #11 Re: OK! Whats better for PCM tune?
    Jan 2015
    Minnesota
    Sweet thanks.. Also any ideas what could cause this? Seems like my tranny is fluttering but only 60-70..http://m.youtube.com/watch?v=BUUWklI8pjs
  12. #12 Re: OK! Whats better for PCM tune?
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by Goldenrocket06 View Post
    The torque converter on these cars doesn't lock up until the trans fluid temperature hits 69 degrees. Depending on how cold of a day it is, it could be a good 15 minutes before the trans warms up.
    Alternatively, you've possibly got a torque converter issue.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  13. #13 Re: OK! Whats better for PCM tune?
    Aug 2013
    McDonald PA
    Quote Originally Posted by hensleya1 View Post
    False. 78 degrees
  14. #14 Re: OK! Whats better for PCM tune?
    Jan 2015
    Minnesota
    Thing is it does it even when the tranny is warmed up to 195.. So torque converter most likely then?
  15. #15 Re: OK! Whats better for PCM tune?
    could be the tcc solenoid. scan the car for a code that maybe pending still. a tune wont help that at all.
    does it do that if you put the trans in 3 rd gear? a worn out 4 th hub will do that too. but being a 06 it should have the hardened shaft from the factory.
  16. #16 Re: OK! Whats better for PCM tune?
    Jan 2015
    Minnesota
    No doesn't do anything bad in 3rd. Drove all the way to St. Paul yesterday in third.. I'll take a look for a code.. But don't you need a special stealership reader tho?
  17. #17 Re: OK! Whats better for PCM tune?
    the free scanner from a parts store will pick up trans codes.
    t app also reads codes, and theres cheap under 20 shipped scanners that work just fine too. i have both of those. running and waiting in line then dealing with a fool and a scanner gets old. so bought my own.
    the scanner i got http://www.ebay.com/itm/U480-OBD2-OB...086791&vxp=mtr
  18. #18 Re: OK! Whats better for PCM tune?
    Jan 2015
    Minnesota
    It drives fine in 3rd. Drove it all the way to St. Paul no issues in 3.. But to check tranny codes don't you need a special stealership reader?
  19. #19 Re: OK! Whats better for PCM tune?
  20. #20 Re: OK! Whats better for PCM tune?
    Jan 2015
    Minnesota
    Just a question, is there a good iPhone app? Was looking at one that looke pretty legit but was skeptical
  1. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  2. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  3. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  4. Whats your AVG MPG?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 07-18-2009, 12:14 AM
  5. whats up
    By qball98 in forum Introductions/Noob Questions
    Last Post: 05-07-2009, 11:27 PM
