Thread: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Did the ground for the icm come off?
  2. #22 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    We determined if has spark n fuel and we did check pressure when cold
  3. #23 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    ever do a tune up? plugs maybe shot to hell.
    a clogged up cat will also keep the car from running.
  4. #24 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    Well its been determined and checked I have both spark and fuel when we check it
  5. #25 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    New spark plugs and wires cat is cut off
  6. #26 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    So car did start right up after sitting in shop over night told no codes showing. Told him to keep it drive it around n then read for codes then leave it in shop again and see if it starts in the morning and if it does park outside n check the next morning n book up computer right away so it can get codes before battery don't die while trying to start so computer can grab all codes
  7. #27 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    In ever had problems w my car starting last winter except once n it was 60 below out but started up on its own the very next day
  8. #28 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    GTP Level Member
    Oct 2014
    Step on the gas a bit while cranking. FPR may be bad.
  9. #29 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Quote Originally Posted by Slick2500 View Post
    This won't keep a car from starting or running. it's a redundant ground.
    Quote Originally Posted by vallij31 View Post
    Please elaborate on how it was determined and at what point you checked it. If you check it when it runs, that's not a good test. If you checked fuel at the fuel rail..then that's only telling you that fuel is at the rail, not in the cylinders.
  1. 2001 grand prix wont turn off
    By 01whitegp in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-24-2012, 07:23 PM
  2. Might buy grand prix. help on engine fire!
    By Fox in forum General Grand Prix Discussion
    Last Post: 02-28-2012, 10:43 PM
  3. My Grand Prix cranks, but doesn't fire
    By Moriachik in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2011, 07:02 PM
  4. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  5. Fire Lights/Siren in '01 Grand Prix
    By iceman977th in forum Visual/Body Modifications
    Last Post: 11-17-2010, 08:55 PM
