Thread: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
Results 1 to 20 of 29
  1. #1 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    I have a 2001 grand prix it will turn over but wont fire. Have replace MAP and MAF sensors, crankshaft position sensor, new plugs and wires. new thromostat, coil packs ignition control module. when this was done and car was running on computer it was running perfectly. the next day it just wouldnt start
  2. #2 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Feb 2013
    37.295091, -121.930053
    does the starter spin? video would be the best help in figuring this out. We could be guessing all day long....
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    starter is fine. I had it taken up to the shop 4 days ago because it wouldnt start. and thats when the cps was changed. Then computer was reading a bunch of misfire is cylnder 6 so changed coil pac. while on computer running after that was running good took the computer off started misfiring so left car at shop. then that was when ignition module was changed. It was running perfectly and properly when computer diagnostic done after that. took car home ran fine til next morning when to start. doing the same thing it was when i took it to the shop. it will turn over just wont fire. if keep key turn trying to start it will backfire sounding like a shot gun. I will try to get a video up of what sounding like or doing.
  4. #4 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Nov 2010
    Ray MI
    Doesn't fire? That is a good thing these things fire way to much if you ask me.
    1991 Grand prix GT
    1994 Cutlass Supreme
    2000 Grand prix GTP
  5. #5 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    yeah had that happen to me months ago put oil in the car and it started on fire. Manifolds get way to hot. I was lucky that i was there went it started before it had the chance to ruin my car. There is a recall to have the spark plug wires to be moved out of harms way
  6. #6 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    GT Level Member Hardonyomom's Avatar
    aurora
    Quote Originally Posted by Nates94 View Post
    I was thinking the same thing..... then i thought , damn that thing looks good low!
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  7. #7 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    Oh and about 2 weeks ago took the catalytic convertor off and put a pipe in because there was a code coming up for the catalytic convertor.
  8. #8 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    Well cylinder 3 and 6 keep missing. Coming to the conclusion its a wiring harness. Does anybody have a clue which one it could be?
  9. #9 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    I would check to make sure you have spark from the 3 & 6 coil pack, from both posts. Then if thats fine, see if you have power/signal at the injector plugs. Im slowly learning and taking a shot in the dark here but is it possible too that coolant is leaking into those cylinders?
  10. #10 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    My mechanic just called said the car just started up this morning running perfectly. Last night he checked some wires and clean some of them in a harness but it wouldnt start. and today it just starts and running good nothing coming up on the computer. WEIRD
  11. #11 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    May 2013
    Buffalo, NY
    sometimes they do that man. hopefully it stays that way for yaa
  12. #12 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    Nope don't want to start today
  13. #13 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    So changed tempature sending unit today. Car still won't start here is a video of what it is doing.
  14. #14 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Donating Users timboku's Avatar
    Montgomery, IL
    Seems like its not getting fuel or enough fuel. Spray starter fluid into tb see if it starts, maybe clogged fuel filter, bad pump, fuel.pressure regulator.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  15. #15 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    we did check fuel pressure and it was fine
  16. #16 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    key to run, bang on the gas tank bottom, then crank it again, if it fires up the pump is dead.
  17. #17 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Randomly not wanting to start sometimes but starting other times is the most common symptom of a failing fuel pump.
  18. #18 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    Dec 2014
    mankato, mn
    It seems to only due this when it get cold. let it sit in a warm shop over night and starts up
  19. #19 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    you may have water in your lines if its when cold only. try testing fuel pressure when it wont fire up.
  20. #20 Re: 2001 Grand Prix Gt wont fire!!!!!!!!!!!
    What Scott is saying is ... diagnose this properly and you will find yourself coming to one of two conclusions when it won't start.
    Here's the only two things that are happening:
    No spark
    No fuel
    Once you know which one is the case, then determining what is causing it becomes a lot easier.
  1. 2001 grand prix wont turn off
    By 01whitegp in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-24-2012, 07:23 PM
  2. Might buy grand prix. help on engine fire!
    By Fox in forum General Grand Prix Discussion
    Last Post: 02-28-2012, 10:43 PM
  3. My Grand Prix cranks, but doesn't fire
    By Moriachik in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2011, 07:02 PM
  4. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  5. Fire Lights/Siren in '01 Grand Prix
    By iceman977th in forum Visual/Body Modifications
    Last Post: 11-17-2010, 08:55 PM
