Thread: Oil change good?
Results 1 to 5 of 5
  1. #1 Oil change good?
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    Got an oil change recently. I knew it had 1qt of 10w30 mobil super. Anyway i have a bad valve cover gasket and the oil will slowly leak out of it. After my oil change i looked at the receipt and found that they used service pro 5w30 synthetic blend oil. Well its been about 3 weeks and it hasn't leaked a drop. I found this surprising because its thinner oil so i thought it would've leaked faster but it hasn't leaked at all. Is that good or bad? Not sure....
    '01 GT, OnStar antenna removed, GT emblem on grille, PONTIAC bumper inlay, engine cover and insulator removed, polished stock exhaust tips, 17" Bullitt rims
  2. #2 Re: Oil change good?
    It really doesnt matter what oil you use anymore. It's been 10w30 on the cap from 95-03, then 5w30 because of a different oil pressure spring. 5w30 meets the requirements of 10w30 from way back.
    But in reality everyone just runs 5w30 because of the climate they live in, the reason for it not leaking/seeping as much is as good as saying your guess is as good as mine.
  3. #3 Re: Oil change good?
    GTP Level Member
    Aug 2012
    st louis park, MN
    What do you mean your car had one quart of oil in it?
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  4. #4 Re: Oil change good?
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    Quote Originally Posted by stocker View Post
    i think he is saying that it had 3 quarts 5w 30 and one quart 10w 30... at least i hope thats what he means lol.
    2000 GT Mods: HAI, 10.5mm wires, rebuilt 60k motor, ZZP stainless headers, magnaflow mufflers, fresh paint job,L-67 top swap, Ported SC...
  5. #5 Re: Oil change good?
    Enfield, CT
    Quote Originally Posted by Pontiac Racer View Post
    Just a heads up, we know what you mean by saying a THINNER oil but try to say SLICKER instead lol cause some people will get on your ass about it.
  1. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  2. Replies: 2
    Last Post: 03-24-2013, 04:45 AM
  3. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  4. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
