Thread: Good ways of tackling rear spark plugs?
Results 1 to 14 of 14
  1. #1 Good ways of tackling rear spark plugs?
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    car has 121xx miles and has never had a tune up which means original plugs. want to change them. rear plugs are a challenge though. any suggestions on how to "make it easier" cause it'll be hard no matter what. would going in from the bottom of the car work? help
  2. #2 Re: Good ways of tackling rear spark plugs?
    SWPA
    Unbolt dogbones, ratchet engine forward,
  3. #3 Re: Good ways of tackling rear spark plugs?
    Or unbolt drivers dogbone.. remove.
    Unbolt passenger dogbone at motor, reposition into additional hole to hold engine forward.
    Then man up.. reach down and do the work.
  4. #4 Re: Good ways of tackling rear spark plugs?
    GTP Level Member
    Aug 2012
    st louis park, MN
    My first (and only) four wheel vehicle plug change was on my grand prix. It was some work but nothing to complain about; likely just a lot more challenging than other cars.
    I folded up a couple towels and set them on the dogbones and just kneeled on top of the engine while working. I didn't move the engine and got it done just fine.
    I would recommend removing the plug wires then blasting each plug with air to remove built up crud and prevent it from falling into the engine. It probably wouldn't hurt to break them loose and blast them again with air.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  5. #5 Re: Good ways of tackling rear spark plugs?
    Quote Originally Posted by stocker View Post
    When was the first time you got screwed by autocorrect? hahahaha
  6. #6 Re: Good ways of tackling rear spark plugs?
    GTP Level Member
    Aug 2012
    st louis park, MN
    I don't get it - that was all intentional grammar.
    Motorcycles have two wheels and 1-4 spark plugs.
  7. #7 Re: Good ways of tackling rear spark plugs?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    The first time I did rear plugs, I ratcheted the engine forward and all of that business... it's not a bad method of doing the OEM plugs if you only do them about every 100K.
    Eventually, I just learned to do it by feel. It's tight back there, but not impossible. I find it easiest to (carefully) climb up on the engine bay and reach down behind the engine. You might just want to try that before going to the trouble of removing the dogbones and what not, maybe it won't be too bad.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  8. #8 Re: Good ways of tackling rear spark plugs?
    Thought you meant 4wd. Dammmmit lol
  9. #9 Re: Good ways of tackling rear spark plugs?
    GTP Level Member
    Oct 2014
    It's not that bad. Do it with a cool engine though and hand start all 3 back there.
  10. #10 Re: Good ways of tackling rear spark plugs?
    ive taken out and re installed my plugs like 5 times in a week. not a big deal.
    for old baked on wires, i like to wear leather work gloves, grab the wire end on the plug, twist it back and fourth, then rip it off. your hand will fly into something, whey the gloves are nice.
    make sure your installing new plug wires too. (30 dollar parts store brand is fine) the old ones are old and dead and do come apart when ripping them off.
    rocking the engine forward is a big help. i stand at the pass side fender and reach to the back to remove them all.
  11. #11 Re: Good ways of tackling rear spark plugs?
    Knoxville, TN
    Should also mention just for kicks (Scotty can back me up on this) that SD headers make spark plug changes super duper easy.
  12. #12 Re: Good ways of tackling rear spark plugs?
    Quote Originally Posted by GTP131 View Post
    id say its not so much the headers, but the fact all the brackets are gone now. lets you see right back down there. and i got enough room now even with my huge hands so i dont have to rock the engine at all now.
  13. #13 Re: Good ways of tackling rear spark plugs?
    Feb 2010
    TN
    I do it by feel never had to move engine forward
  14. #14 Re: Good ways of tackling rear spark plugs?
    Nov 2014
    winston salem,nc
    I just used a small extinction on the ratchet wasn't hard at all just wear gloves for when they break lose
  1. Rear Spark Plugs '07, Noobie needs help!
    By Kuja989 in forum Introductions/Noob Questions
    Last Post: 10-29-2013, 09:22 AM
  2. Rear spark plugs
    By Thompsju in forum Introductions/Noob Questions
    Last Post: 10-23-2013, 07:07 PM
  3. Rear spark plugs
    Last Post: 10-16-2013, 07:59 PM
  4. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  5. I've got an 05 grand prix and I'm having trouble with the rear spark plugs.
    By learningtoworkoncars in forum General Tech Discussion
    Last Post: 09-16-2011, 10:34 AM
