Thread: 3.4 Pulley Question
Results 1 to 20 of 29
psi 3.4 Pulley Question 07-27-2014, 01:15 PM
ILoveAudi Re: 3.4 Pulley Question 07-27-2014, 01:20 PM
hensleya1 Re: 3.4 Pulley Question 07-27-2014, 03:55 PM
whoender Re: 3.4 Pulley Question 07-27-2014, 04:13 PM
hensleya1 Re: 3.4 Pulley Question 07-27-2014, 04:17 PM
whoender Re: 3.4 Pulley Question 07-27-2014, 04:15 PM
hensleya1 Re: 3.4 Pulley Question 07-27-2014, 04:19 PM
whoender Re: 3.4 Pulley Question 07-27-2014, 04:31 PM
whoender Re: 3.4 Pulley Question 07-27-2014, 04:34 PM
hensleya1 Re: 3.4 Pulley Question 07-27-2014, 04:41 PM
Fivefingerdeathpunch Re: 3.4 Pulley Question 07-27-2014, 04:56 PM
dsmuts Re: 3.4 Pulley Question 07-27-2014, 07:25 PM
psi Re: 3.4 Pulley Question 07-29-2014, 12:15 PM
dsmuts Re: 3.4 Pulley Question 07-29-2014, 03:26 PM
psi Re: 3.4 Pulley Question 07-29-2014, 04:42 PM
psi Re: 3.4 Pulley Question 07-29-2014, 04:34 PM
dsmuts Re: 3.4 Pulley Question 07-29-2014, 05:39 PM
psi Re: 3.4 Pulley Question 07-29-2014, 10:22 PM
psi Re: 3.4 Pulley Question 07-29-2014, 10:28 PM
whoender Re: 3.4 Pulley Question 07-29-2014, 10:40 PM
chris99gtp Re: 3.4 Pulley Question 07-29-2014, 10:46 PM
psi Re: 3.4 Pulley Question 07-29-2014, 10:53 PM
psi Re: 3.4 Pulley Question 07-29-2014, 10:54 PM
whoender Re: 3.4 Pulley Question 07-29-2014, 10:58 PM
dsmuts Re: 3.4 Pulley Question 07-30-2014, 05:47 AM
psi Re: 3.4 Pulley Question 07-30-2014, 12:42 AM
whoender Re: 3.4 Pulley Question 07-30-2014, 12:51 AM
dsmuts Re: 3.4 Pulley Question 07-30-2014, 05:49 AM
whoender Re: 3.4 Pulley Question 07-30-2014, 05:54 AM
  1. #1 3.4 Pulley Question
    Jul 2014
    Iowa
    Picked up my first GTP (03 Red 4 Dr) yesterday aftering selling my SRT-4. It is all stock besides a PCM. I'm going to order my intake, plugs, plug wires, and get my exhaust done this week. What is a good set up for an intake instead of paying $250 I've read of people just putting a cone on the throttle body? If someone has a link to show what brands they went with or why it might be better to pay extra for a name brand that would be great. I was also given pace setter headers and a few other parts like a 3.4 Pulley with no belt. If I want to use the 3.4 what do I all need? Obviously the pulley, a belt, and the tool? Any input is appreciated.
  2. #2 Re: 3.4 Pulley Question
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    First, welcome to the forum! Second, don't waste your time with aftermarket intakes. Most of use spectre filters on our intake setups. There's plenty of different ways to make an intake. I just have my cone slapped right on the tb. The only aftermarket intake setup worth buying is a fenderwell intake. What style 3.4 pulley is it? Is it a modular or a press-on? You'll also want a tune after headers and pulley. I personally don't believe in running a 3.4 on just headers and tune, but a lot of guys do. That's just my pov on it.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  3. #3 Re: 3.4 Pulley Question
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by psi View Post
    Help in no particular order, so hope it helps:
    Spectre sells open cones for $25 at your local auto parts store. Get yourself some tubing (I used 3" PVC pipe from Lowe's) to route the air intake into the fender well. Rip out the stock air box and zip tie the PCM to something so it won't rattle around.
    You'll want a shorter supercharger belt with a 3.4" to discourage any belt slippage.
    Not sure about pacesetter headers but I know for most other headers (SD's for instance) you'll need a front 02 extension or it won't fit.
    For any headers/pulley drop you'll need a tune afterwards... firstly to delete the rear 02 SES light which *will* come on and to tune for the new setup.
    Depending on whether your car is stock... and depending on whether the 3.4" is a press-on or modular system, depends on how much work you do. The modular pulleys work by pressing on a hub, and then you can change out pulleys with a few Allen bolts. Something still has to get pressed on/pressed off though. ZZP, Intense, etc. have pulley pullers. Don't use an AutoZone pulley puller or you'll have to buy a new supercharger snout when you're done.
    When running a 3.4 on just headers... Scan, Scan, Scan. Get yourself an Aeroforce, Scanguage, Scanmaster, Torque App, etc... anything that scans for KR. KR is Knock Retard... when the computer senses detonation in the engine (pinging/knocking), it automatically yanks ignition timing to stop the detonation.
    You'd rather run a larger pulley with no KR than a smaller pulley with KR, because when you yank timing you lose a LOT of horsepower - IIRC 3-5 hp per degree of KR. Keep at it long enough and you'll chip pistons, which means it's time for a new motor. So be prepared, if you run into KR, to pulley up or do some more supporting mods.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  4. #4 Re: 3.4 Pulley Question
    SE Level Member whoender's Avatar
    Jul 2014
    I am new to v6 power plants. I am (was) a v8 carb muscle car guy. I started to just do an intake gasket but I decided I want to add hp. The heads are off and is there anything I can do, without breaking the bank to them or is the 3.5 pulley, tb spacer, colder plugs, and cold air intake enough to get started?
  5. #5 Re: 3.4 Pulley Question
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by whoender View Post
    Get you some headers before pulley dropping. Speed Daddy, SSAC, etc, can be had for the $200 range. The immediate problem with these cars before you do any bolt-ons is the exhaust. By the cat, where the rear 02 sensor plugs in, there's a U-bend in the exhaust. Your 2.5" becomes more like 1.75" but only for a few inches. Not good.
    A downpipe can solve this and is less labor intensive than headers but at $150-180 new... you might as well pick up some headers. If you're a real cheapo and have a welder you can just get the U-bend delete from ZZP for like $40 but you'll kick yourself before long and ask why you didn't get headers.
    Thing is, most cars in stock form already have a little KR at the top of second gear (2-3*) because of exhaust restrictions. So getting the exhaust out is a priority before doing anything else... tb spacers, colder plugs, intake, etc... they help, and I wouldn't skimp on them, but they won't by themselves let you pulley drop.
  6. #6 Re: 3.4 Pulley Question
    Jul 2014
    Also where is the most cost effective place to purchase a mod pulley?
  7. #7 Re: 3.4 Pulley Question
    Jun 2013
    Beavercreek, OH
    Any W-body place (W Body Store, ZZP, Intense, etc.) will have them in stock. Most will rent out pulley pullers as well. Me, I drove up to Intense and they did a pree pulley hub install when I bought the hub, so that made it easier for me, since Intense was about an hour's drive away in Columbus.
    Also, there's people around the forums who have pulley pullers and possibly used hubs/pulleys for cheap. Troll around the for sale forums... you might find what you're looking for, for less.
  8. #8 Re: 3.4 Pulley Question
    Jul 2014
    I already eliminated the 😻 and I have and am a welder. So what you are satisfied let's make it "flow"
  9. #9 Re: 3.4 Pulley Question
    Jul 2014
    Headers and downpipe, should I do anything to the heads? I am a tech and have been for over 20 years so the labor is not a problem
  10. #10 Re: 3.4 Pulley Question
    Jun 2013
    Beavercreek, OH
    Most headers will come with a downpipe already. Assuming you live in an area that doesn't have inspections... scrap that cat and get some of your money back.
    You don't have to do anything to the heads on a 3.4 setup with headers. If you want to get more serious, you could run high ratio rockers or an S1X cam... although in either case you'd need stronger valve springs (and there would be reliability and performance gains by upgrading the lifters and pushrods at this point), it isn't essential. If you wanted to run a bigger cam... an XP, an S2 or S3, etc... then you'd need some ported heads.
    This thread is a pretty good start and will repeat many of the things I've hit on here. It's not perfect, but it's got most of the info on hand:
    http://www.grandprixforums.net/threa...ding-Your-3800!
  11. #11 Re: 3.4 Pulley Question
    You can clean the heads up if ou wished. They are poorly cast and cleaning each runner wouldnt hurt.
    TB spacers are junk, just a coolant leak waiting to happen.
    And anything exhaust wise after the cat is worthless unless you make some crazy horsepower over 350-400+ to the wheels. The factory 2.25 flows plenty for a 6 cylinder. Add mufflers for sound if you wanted but most will sound like ass and drone.
  12. #12 Re: 3.4 Pulley Question
    Port the heads
  13. #13 Re: 3.4 Pulley Question
    Jul 2014
    Iowa
    Been reading up a little bit and think I'll go in the order of: intake>plugs+plug wires, then exhaust+3.4 Pulley setup+tune at once. Is there any good programmable tuners out there for our cars? Always had the Diablo Sport Predator for my SRT. Or is it best to just get it done on a dyno?
  14. #14 Re: 3.4 Pulley Question
    You can buy a dhp or hpt
  15. #15 Re: 3.4 Pulley Question
    Jul 2014
    Iowa
    Can somebody list a parts list from stock to a reliable setup with noticeable power including my 3.4 modular pulley and headers+downpipe that I already have? Confused..
  16. #16 Re: 3.4 Pulley Question
    Jul 2014
    Iowa
    Previous owner had a ZZP PCM installed when I bought the car, obviously it still needs to be tuned after the exhaust and pulley setup anyways right?
  17. #17 Re: 3.4 Pulley Question
    A zzp 1.0 pcm would be fine to run on a 3.4 setup just make sure you scan for KR.
  18. #18 Re: 3.4 Pulley Question
    Jul 2014
    Iowa
    Thanks. And as for exhaust I have the headers and cat'd downpipe. I'm looking to have a local shop put it on for me What else do I need being they can straight pipe it from the cat back? I don't really care what kind of sound, too quiet or too loud (hopefully not super loud), it makes I'm looking for performance here. And where can I get this o2 extention I need for my pace setter headers? Also I called the previous owner just to verify what is stock and what isn't. The car is stock besides, the 1.0 ZZP PCM and an SLP Cold Air Induction Package.
    So that being said my questions are:
    1. What other exhaust parts do I need beside my headers and downpipe for the biggest benefits?(performance>sound)
    2. I'm fine to run the 3.4 Pulley Setup with my PCM?
    3. My current parts list minus the PCM, Intake, headers and dp I already have is:
    -ZZP 180 Degree Thermostat
    -Taylor Cable 8mm Plug Wires
    -Autolite Spark Plugs from ZZP
    -S/C Oil Change and a Coolant Flush
    -Mufflers or Resonators (if needed because of sound)
    Let me know if I should change, add, or remove anything from the list. Thanks
  19. #19 Re: 3.4 Pulley Question
    Jul 2014
    Iowa
    Oh, and obviously a Scan Guauge. Brands? The cheaper the better, not too concerned on looks just price and quality.
  20. #20 Re: 3.4 Pulley Question
    Jul 2014
    psi, I am a tech and have a shop. My prices are the lowest around. Where are you located
  1. Pulley question
    By jakegee01 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2012, 11:49 AM
  2. pulley question
    By Toms04compg in forum General Grand Prix Discussion
    Last Post: 02-07-2012, 06:05 PM
  3. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  4. pulley question
    By novmadman in forum General Tech Discussion
    Last Post: 02-08-2009, 07:05 PM
  5. another pulley question
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:32 PM
