Thread: Exhaust Setup?
Results 1 to 6 of 6
  1. #1 Exhaust Setup?
    Jul 2014
    Iowa
    I have Pacesetter headers and a downpipe that were given to me when I bought my car last week ('03 GTP). I want to do my exhaust first before my 3.4 Pulley Setup, looking to do the exhaust and order the 3.4 Pulley Setup this week. My question is, to use the Pacesetter headers and downpipe will I need a o2 extention, and if so where do I get this? And since I have the downpipe what else to I need for a good setup? Sound doesn't bother me but obviously not ridiculously loud. I want a setup best for performance. Would I be best off going straight back from the catted downpipe with just mufflers? Or resonators too? If anyone could give me pointers on what to buy in order to have a less restrictive, performance setup that would be great.
  2. #2 Re: Exhaust Setup?
    Zzperformance for the extension and not sure if you'll need one or not.
    Keep the stock resonator.. Hell keep the rest of the exhaust stock.. Your already addressing the restrictive areas by going with the headers... The rest of the exhaust is fine until your around 350hp or so when the rest is restrictive which you probably will not reach that point.
    04 Comp G.
  3. #3 Re: Exhaust Setup?
    Jul 2014
    Iowa
    Alright, thanks. Don't plan on going over 350. Is this the right o2 extention? http://shop.zzperformance.com/store/...-Extender.aspx
  4. #4 Re: Exhaust Setup?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    It is the only one. Lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  5. #5 Re: Exhaust Setup?
    Jul 2014
    Iowa
    Exactly why I'm posting in the noob section.^ Thanks anyways just got it all ordered.
  6. #6 Re: Exhaust Setup?
    Oct 2011
    Toledo, OH
    Jesus christ, that isn't what you need. You need an O2 cable harness extension, because headers move the upstream O2 sensor further away. That part there is to get the downstream O2 sensor out of the gas flow to avoid a p0420 code on high flow cats, aka anti-fouler trick.
    7"
  1. what do you think about this exhaust setup?
    By kking89 in forum Shops and Community Heroes
    Last Post: 02-04-2014, 05:32 AM
  2. What exhaust setup should I get?
    By Pokealong1227 in forum General Tech Discussion
    Last Post: 01-02-2013, 10:35 PM
  3. an idea for an exhaust setup
    By RobGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2011, 08:17 PM
  4. exhaust setup
    By reem98 in forum General Tech Discussion
    Last Post: 07-14-2011, 10:53 AM
  5. exhaust setup
    By CTKGP09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:08 AM
