Thread: Transmission plug
Results 1 to 20 of 32
  1. #1 Transmission plug
    SE Level Member DirkJr's Avatar
    Apr 2014
    East Peoria, IL
    I just got my transmission back in and besides my rack falling out and some of the bell housing bolts not lining up, it went somewhat smooth. Now I have the round plug on the drivers side not going in because the pins on the trans are all f'd up. This is on a 98 GTP. How necessary is this plug/ what is it actually for?
    Using Tapatalk
  2. #2 Re: Transmission plug
    Dec 2010
    DMV
    I believe that plug is for everything trans related. Overdrive and shifting and all that jazz. So in other words, you need it.
    Sent from my HTC One using Tapatalk
  3. #3 Re: Transmission plug
    pics would help
  4. #4 Re: Transmission plug
    Apr 2014
    East Peoria, IL
    ImageUploadedByTapatalk1398209066.057156.jpg this connector.
    Using Tapatalk
  5. #5 Re: Transmission plug
    That is the very important. It needs hooked up. Straighten the pins and plug it in.
  6. #6 Re: Transmission plug
    Apr 2014
    East Peoria, IL
    This oughta be fun.... Also does anything hold the shaft into the boot on the firewall or does the subframe just hold it up?
    Using Tapatalk
  7. #7 Re: Transmission plug
    a bolt holds it on.
  8. #8 Re: Transmission plug
    Apr 2014
    East Peoria, IL
    For the rack and pinion? I've looked for somewhere a bolt would be and found nothing.
    Using Tapatalk
  9. #9 Re: Transmission plug
    at the end of the shaft is a hole where a bolt goes once its on the rack, its a 11 mm iirc. and you need a good 12 inch of extentions to get to.
  10. #10 Re: Transmission plug
    Apr 2014
    East Peoria, IL
    Does anyone have a pic? It just fell out so I assumed it didn't have one.
    Using Tapatalk
  11. #11 Re: Transmission plug
    The knuckle is still in there then.
  12. #12 Re: Transmission plug
    about 5:20 he shows the boot.
  13. #13 Re: Transmission plug
    Apr 2014
    East Peoria, IL
    I just have to oval-like shafts that slide into each other.
    Using Tapatalk
  14. #14 Re: Transmission plug
    post a pic of whats going on.
  15. #15 Re: Transmission plug
  16. #16 Re: Transmission plug
    Apr 2014
    East Peoria, IL
    I think I see what need to be done and where the bolt should be.
    Using Tapatalk
  17. #17 Re: Transmission plug
    Back out the torx or hex screw and get it back on the column. DO NOT TURN the steering wheel more than a 1/4 turn right now. You'll screw the clockspring if it's turned around and around.
    Scott..the part you show is just below where it meets the column. It's oval with flat spots..has one dinky tiny why the eff is it so small set screw that holds it and lets it telescope. I think out of all the drops, I've had two fall. When that happens..it's fun to get back together.
  18. #18 Re: Transmission plug
    SE Level Member A98GTP's Avatar
    Apr 2014
    Texas
    That set screw made me want to find the engineer responsible and request 5 minutes alone with him in a locked room.
  19. #19 Re: Transmission plug
    I didn't find the screw to be as bad as...say the location..lol
  20. #20 Re: Transmission plug
    Apr 2014
    Texas
    Should come with a warning about not attempting this step until you can touch your right elbow with your right index finger and fold your body into a suitcase.
    Then again half the jobs on this car should say the same.
  1. Help me. What is this plug?
    By GinjaSlice in forum General Tech Discussion
    Last Post: 04-08-2013, 12:27 AM
  2. 2008 Base model plug and plug wire swap
    By MS1227 in forum 04+ Specifics
    Last Post: 12-06-2012, 06:14 PM
  3. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
  4. Where does this plug go (2) ?
    By clush in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-14-2011, 09:20 AM
  5. transmission harness plug smashed
    By threlfall92 in forum Introductions/Noob Questions
    Last Post: 05-03-2011, 12:20 PM
