These cars aren't that bad. This one thing.. yeah..it's a pain. Usually a boot is sacrificed
when i got my car the last owners must have attempted a tune up, but only changed one rear plug, 2 were way older looking and a different brand all together.
unbolt the dog bones then with a ratchet strap pull the engine forward this will give you a good 3 inches of extra room, enough to see the plugs now.
the middle rear iirc is the one blocked by the o2 sensor, i put the socket on the plug, then was able to just put the tip of a 3 inch extension in the socket, then broke it free. you'll see what i mean when you get to that plug.
or if you have real spark plug sockets that have a bolt head at the top, use a wrench on the plug socket to break it free.
ImageUploadedByTapatalk1398359962.218089.jpg just so you guys have an idea on what I'm dealing with.
Can't tell from the pic, what I'm even looking at.
Looks like a fuzzy iphone pic.
OH.. you need this.
http://www.grandprixforums.net/threa...ide+cover+easy
You'll need to pull the side cover and replace that wiring harness
Ouch yeah that connector has to be replaced. I think you will have to drop the pan and unclip all the solenoids and such. I really dont know on these transmissions though. I have never had one apart. From previous experience on other transmissions (4L60/4L80/5R55/4R70/4R100) you have to drop the pan.
