What up what up soooo I bought this car about 2 months ago from an auction car was leaking coolant from underneath right side also had a crack radiator. I replaced the radiator figure it would stop the leaking nope no luck I haven't had time to go underneath and check it out. the leak is coming from under the car a plate is blocking it. As I was driving on the freeway my hose blew off in the back tof he engine, the car overheated so I checked out the hose and it seemed to have warped the metal plate that holds it in. So after putting the hose back in the car seems to be riding hotter then usual when i come to a stop it will heat up then go down or stay warmer , o yea on the freeway if I'm coasting the check coolant light comes on if I'm going 65 it goes away
