Thread: "Tune up" performance, exhaust, possible mods and Seafoam?
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 103
  1. #21 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    Enfield, CT
    I concur, bosch is dog ****
  2. #22 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    May 2013
    Lansing, MI
    So I guess during the design phase they Bosched things up?
    I know, bad joke.
    Now regarding seafoam, that is definitely first on the list, obviously before new plugs. Is this a two person job? I've seen videos and usually someone is revving the engine while another is pouring it in the throttle body. Is there sure way to do this without locking things up? I also read differences as far as what lines to have it delivered.
  3. #23 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    Enfield, CT
    it it easier with 2 people but DO NOT dump the whole can in. Some people do that and **** their **** up and some people are fine. Not worth it. only do 1/3 of the can and put it into the brake booster vac line.
  4. #24 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    May 2013
    Lansing, MI
    I read that some people heard horror stories regarding using seafoam in the oil. Should I skip that part completely? My car is high mileage, 170k.
    There are only two types of people. There are idiots, and then there are the ones that are good at hiding the fact that they are idiots.
  5. #25 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    pass on the oil part. use 1/3 in the gas tank then suck up 1/3 through a vac line. save the last 1/3 for a fuel treatment down the road.
  6. #26 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    May 2013
    Lansing, MI
    Should I spray and in the throttle or does the vac line take care of that?
  7. #27 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    you can take the brake booster vac line off the brake booster, pinch it to keep the car running, while pouring the sea foam into the vac line. this is the fat hose that runs to the fat round brake booster.
    either dump the last little bit in to stall the engine or shut it off when the 1/3 of a can is ingested. wait 20 minutes and let the smoke show begin.
  8. #28 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    the TB your best to take it off and clean it. seafoam wont really clean that.
  9. #29 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Simple easy mods
    Diy intake. Plog from zzp, bigger downpipe, hv3 insert from zzp,and rockers if you want to keep spending, and a overkill tune to finish it up.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  10. #30 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    Since you don't want to top swap I'd recommend you get an HV3 insert, 2.5" downpipe because with a 3" you tend to lose some of your low end torque since it's an N/A, look at a PLOG, maybe rockers or a cam and then get a tune from wherever you find to be best.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  11. #31 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    Enfield, CT
    I thought plogs were useless on n/a?
  12. #32 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    May 2013
    Lansing, MI
    One more thing regarding seafoam before I start doing it. Everyone seems to say 1/3 in the gas tank. The directions say one whole can or 1 oz per gallon. The car has 17 gallons. Should I listen to what everyone else says or what? Also as of right now I have a full tank, should I drive some of it off or go ahead and put it in?
  13. #33 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    Doesnt really matter.
    Go to your profile and make this your sig, instead of typing it out every post.
  14. #34 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    Aug 2012
    MIAMI
    Lol
    Sent from my SGH-M919 using Tapatalk
  15. #35 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    May 2013
    Lansing, MI
    It is my sig. I'm using tapatalk so that might be the problem
  16. #36 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    The directions on the can are for using it as a fuel treatment. I prefer to put 2/3 in my tank then the 1/3 in the brake booster.
    Sent from A Galaxy Far Far Away........
  17. #37 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    Howell, NJ
    Don't put it in your brake booster if your supercharged.
    Its harsh on the rotor coating
    Use the vac port under the sc snout
    Edit: I'm. Dumb and I don't read op is na
  18. #38 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    There is a lot of debate over whether or not the coating on the rotors even affects anything
  19. #39 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    May 2013
    Lansing, MI
    I just saw a video on YouTube posted by O'Reiley auto about seafoam. They demonstrated using the spray in the throttle body. Should I do that or is it too risky to do on my car.
  20. #40 Re: "Tune up" performance, exhaust, possible mods and Seafoam?
    it cant hurt, if your maf is in the tb remove it first.
    ive used that on small engines, works just as good as the bottle.
  1. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  2. Finally buying first "Performance mod"
    By kking89 in forum General Tech Discussion
    Last Post: 05-07-2012, 09:36 PM
  3. Any 2.25" in by 3" out by 5" long exhaust tips out there?
    By Xanthous in forum Visual/Body Modifications
    Last Post: 06-05-2011, 09:09 PM
  4. Idea for a "performance" headlight set up (visual aid added)
    By Agentlongwood in forum Visual/Body Modifications
    Last Post: 03-01-2011, 02:43 PM
