Thread: Engine leaking near pulleys
Results 1 to 10 of 10
  1. #1 Engine leaking near pulleys
    Jan 2013
    Tolono IL
    I found this liquid kind of like oil. Maybe power steering fluid near the pulleys anyone know what it is? And why is it leaking?
  2. #2 Re: Engine leaking near pulleys
    id start with 2 cans of de greaser, clean the engine and tranny up all nice. then keep a eye on it over the next few days looking for the leak source.
  3. #3 Re: Engine leaking near pulleys
    Jan 2013
    Tolono IL
    Yeah I'm going to. Just never seen this happen before. Could it be intake gasket?
  4. #4 Re: Engine leaking near pulleys
    Seen the lower intake and valve cover gaskets leak oil down there.
  5. #5 Re: Engine leaking near pulleys
    Jan 2013
    Tolono IL
    Rear valve cover was just replaced not to long ago.
  6. #6 Re: Engine leaking near pulleys
    Jan 2013
    Tolono IL
    Alright took it to my mechanic to look at it and it's the water pump. The gasket is bad and he thinks the water pump could be bad too
  7. #7 Re: Engine leaking near pulleys
    its possible. its a 40 dollar job if your up to it your self. very easy to change really.
    engine off, grab the water pump pulley with both hands, then push one side pull the other, then back and fourth, if you feel play, the pump is bad.
  8. #8 Re: Engine leaking near pulleys
    Jan 2013
    Tolono IL
    Would I have to take the belt off to test it?
  9. #9 Re: Engine leaking near pulleys
    no sir. leave the belt on for the test.
  10. #10 Re: Engine leaking near pulleys
    Jan 2013
    Tolono IL
    Thanks!
  1. Modded fuel rails leaking and engine knocking when mashing the gas
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2014, 05:02 PM
  2. TB and Pulleys
    By dbextreme in forum Wanted To Buy - Parts
    Last Post: 02-16-2013, 02:28 PM
  3. 97 GTP Leaking Coolant after turning engine off?
    By Bjm5295 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2012, 06:26 AM
  4. Leaking fuel from passenger side of engine!
    By 97gtpfreak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2012, 12:10 PM
  5. Replies: 2
    Last Post: 08-04-2011, 08:58 AM
