Thread: wheel hub assembly
Results 1 to 5 of 5
  1. #1 wheel hub assembly
    Feb 2014
    iowa
    I have a 2005 Grand Prix that needs a new driver side front wheel hub assembly, the car doesn't have ABS but the wheel hub i got with the car is for ABS will this wheel hub work?
    Thank You for the help.
  2. #2 Re: wheel hub assembly
    it should, just clip the plug off if need be.
  3. #3 Re: wheel hub assembly
    Enfield, CT
    don't recommend clipping the plug off since some parts stores will refuse to warranty the part if ever needed. just zip tie it if the hub bracket doesn't have a spot for it to clip on
  4. #4 Re: wheel hub assembly
    ^ that
    04 Comp G.
  5. #5 Re: wheel hub assembly
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    yes it will work
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  1. Wheel bearing/hub assembly questions
    By 01STOCKGTP in forum General Tech Discussion
    Last Post: 05-16-2015, 05:21 PM
  2. Wheel Hub Assembly Part
    By Clifford Colvard in forum Shops and Community Heroes
    Last Post: 05-07-2012, 07:34 PM
  3. need help removing rear wheel bearing hub assembly
    By tiedye in forum Off Topic Discussion
    Last Post: 04-26-2011, 07:15 AM
  4. Help Please: Steering wheel re-assembly
    By Sinnoth in forum General Tech Discussion
    Last Post: 10-21-2010, 10:45 AM
