Thread: Wheel bearing/hub assembly questions
Results 1 to 11 of 11
  1. #1 Wheel bearing/hub assembly questions
    SE Level Member 01STOCKGTP's Avatar
    Nov 2010
    Michigan
    First, What brand is best for the price? I have heard timken and moog are good.
    Second, Belltire told me I have a bad wheel bearing... they wanted like 300 some bucks to fix it so i said screw that! It isn't making any noise at all so how do they even know it needs to be replaced?
  2. #2 Re: Wheel bearing/hub assembly questions
    movement.
    jack up the car and grab at 12 and 6 and shake, if you feel movement, then its a bad wheel bearing.
    id go with a timkin bearing.
    replacing them is not too hard, normal hand tools and big socket for the axel nut are needed as well as a torque wrench.
  3. #3 Re: Wheel bearing/hub assembly questions
    Ohio
    timken aint quality bearings anymore. honestly it doesnt matter what you get. i put the moogs on mine just because i work at advance.
  4. #4 Re: Wheel bearing/hub assembly questions
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    What makes the Moog that much better?? The fact that Advance Auto carries them instead of Timken??
    Timken Bearings @ Rockauto.com is your best bet.
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  5. #5 Re: Wheel bearing/hub assembly questions
    Jan 2013
    Texas
    Do u know if the rear wheel hubs come prepacked with grease
  6. #6 Re: Wheel bearing/hub assembly questions
    SWPA
    97+ are sealed units.
    I don't know enough about the previous gens and you didn't specify what year you were asking about.
  7. #7 Re: Wheel bearing/hub assembly questions
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I put Timkens on my regal, about $100 each, they gotta be better than the $40 no name ones that everybody in the reviews were replacing every 6 months.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  8. #8 Re: Wheel bearing/hub assembly questions
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    I do about two-4 hubs a year on my two gtps. but thats the cheap ebay wheel hubs
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  9. #9 Re: Wheel bearing/hub assembly questions
    Jan 2013
    Texas
    @stealthee - 2002 gtp but you answered my question anyways. reason why im asking is cause it constantly squeals. i might have the ebrake pads in a wrong position but i dont know.
  10. #10 Re: Wheel bearing/hub assembly questions
    Delaware County, PA
    Timkin and Moog are both good and have a loyal following. Timkin has 1 year warranty; Moog has 3 year. Moog I heard is made in both China and USA.
  11. #11 Re: Wheel bearing/hub assembly questions
    timkens a 3 year warranty, and i bought one and replaced it 2 or 3 times already. ive done the hubs a lot it seems, cant keep track no more.
  1. Front axel bearing and hub assembly replacement
    By BSMet94 in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2011, 11:34 AM
  2. wheel bearing hub
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 09:43 AM
  3. need help removing rear wheel bearing hub assembly
    By tiedye in forum Off Topic Discussion
    Last Post: 04-26-2011, 07:15 AM
  4. Wheel Hub Bearing questions?
    By dew1520 in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2009, 08:42 PM
  5. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
