Thread: F-Body brake rotor question
Results 1 to 11 of 11
  1. #1 F-Body brake rotor question
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    I am still thinking on doing the infamous F-Body brake upgrade, but I noticed something while researching it. If I am understanding it correctly, you use the rotor and caliper and bracket from a 98 - 02 F-Body. Now, does the GP not have a 5 x 115 bolt pattern, while the F-Body has a 5x120 bolt pattern. What is my messed up brain missing? How will the rotors off of an F-Body work with the GP wheels??
    P.S. I posted this in this forum, because it has all the markings of a major noob question.
  2. #2 Re: F-Body brake rotor question
    The wheel stud are in the wheel hub, and the rotors clear the wheel studs.
  3. #3 Re: F-Body brake rotor question
    If you look up the bolt pattern of the rotors, they're between 115 and 120. The holes are also very large.
    They're designed by GM to fit both bolt patterns as they use the same rotor on the 00-05 Impalas (and so on) as well as 98-02 F body.
    The only time you'll run into issues there is if you try to run the Baer Eradispeed rotors. They're drilled for 5x120 and will need to be drilled again for 5x115.
    Or you could just call and ask for specially made hats.
  4. #4 Re: F-Body brake rotor question
    Mar 2013
    Manitoba, Canada
    Interesting. How do the f-body rotors get centred on the hubs then? Is the big hole the same, and that is what centres it?
  5. #5 Re: F-Body brake rotor question
    Yes, the bore is identical.
    4.75" is 120.3, the standard version of 120.
    4.5" is 114.3, the standard version of 115.
    4.65 is 118. Magic.
  6. #6 Re: F-Body brake rotor question
    Mar 2013
    Manitoba, Canada
    Thank you very much everyone. Wish I could get that quick of service everywhere!!
  7. #7 Re: F-Body brake rotor question
    Omaha, NE
    I second everything that was stated in this thread.
  8. #8 Re: F-Body brake rotor question
    Jan 2012
    Philadelphia
    So if I went to AutoZone and bought rotors for example: 00 T/A WS6 they will fit on a GP with the F-Body Calipers? The rotors have a bolt pattern for 115 and 120? Curious because I will be doing this upgrade soon. Is there a writeup on here for the swap?
  9. #9 Re: F-Body brake rotor question
    There is one on club gp. When I get on my Pc I'll post the link.
    Sent from A Galaxy Far Far Away.....
  10. #10 Re: F-Body brake rotor question
    Pennsylvania
    So when I buy my r1 rotors, and I order them for a 2000 Camaro, they'll fit the GP? I dunno if they custom drill them specifically for 5x120, or if I'll have to ask them for the specific pattern.
    Sport Edition Kv5 18x8
  11. #11 Re: F-Body brake rotor question
    GT Level Member atj8's Avatar
    Midwest
  1. Rear brake rotor question.....
    By Spike89 in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2013, 11:36 AM
  2. F body brake upgrade question
    By Austins01GP in forum General Tech Discussion
    Last Post: 06-28-2013, 03:58 PM
  3. F-Body brake question
    By asite57 in forum Brakes/Suspension/Chassis
    Last Post: 06-11-2012, 11:42 PM
  4. Brake Rotor Question
    By SNeitzel in forum General Tech Discussion
    Last Post: 10-01-2010, 12:21 PM
  5. brake rotor.
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 09-24-2009, 02:32 PM
