Thread: 01 prix, headlights turn off when blower fan is between pos 1-4 works only on high
Results 1 to 4 of 4
  1. #1 01 prix, headlights turn off when blower fan is between pos 1-4 works only on high
    Oct 2013
    akron oh
    help
  2. #2 Re: 01 prix, headlights turn off when blower fan is between pos 1-4 works only on hig
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Blower resistor. This is basically behind the glove box. At least, that's why your fan is only working on high. As for the headlights, that's a bit odd. I'd blame gremlins...
  3. #3 Re: 01 prix, headlights turn off when blower fan is between pos 1-4 works only on hig
    Banned
    Oct 2013
    Moorhead, MN
    Meh. There was a TSB on this pointing to the ignition. One of the fixes was to wire in a resistor.
    TSB #PIC-5351ANHTSA ID #10042292
    Date Announced:
    OCTOBER 11 2011
    Additional Info:
    How to Fix
    SUMMARY:
    PONTIAC: CERTAIN VEHICLES ARE EXHIBITING INOPERATIVE BLOWER MOTOR, EXCEPT ON HIGH SETTING OR DRL'S INOPERATIVE OR HEADLAMPS INOPERATIVE RATHER HIGH OR LOW BEAMS AND THE REAR WINDOW DEFOGGER IS INOPERATIVE. *
  4. #4 Re: 01 prix, headlights turn off when blower fan is between pos 1-4 works only on hig
    Enfield, CT
    Yea definitely look at the ignition switch. it's a common problem and so is the blower motor resistor.
  1. 98 grand prix blower doesnt turn on
    By Adk247 in forum General Tech Discussion
    Last Post: 07-12-2012, 12:03 PM
  2. Turning on (nonworking) blower causes headlights to turn off
    By chilipepperpizza in forum General Tech Discussion
    Last Post: 05-03-2012, 11:14 AM
  3. Blower motor only works on high.
    By 99gpse in forum General Tech Discussion
    Last Post: 04-15-2012, 12:08 PM
  4. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  5. 1997 GTP headlights turn off when blower fan is turned on, except setting #5 (high)
    By 93Chewbacca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2011, 07:23 AM
