Thread: Power Steering Leaking from Tie Rod Boot
Results 1 to 15 of 15
  1. #1 Re: Power Steering Leaking from Tie Rod Boot
    Jun 2011
    Ohio
    Thanks for the informative guide! I wasn't expecting so much information by any means!
    In any case, my mechanic buddy that I work on my car with mentioned that my subframe is starting to rot out pretty hardcore, so this may end up being the most labor-intensive job we've had to do on it thus far.
    Assuming I can find one in decent condition from a scrapyard, that is.
    Also, what do you mean by "turn handle jack stands"? I have two aluminum jack stands I bought from Harbor Freight, and their combined weight limit is about 3k lbs (the car weights 3.8+ from what I read on specs awhile back, plus aftermarket stereo equip..)
    Link to them - http://www.harborfreight.com/3-ton-a...nds-91760.html
    Link to aluminum jack I bought - http://www.harborfreight.com/aluminu...ons-68054.html
    I wasn't expecting to need something extremely heavy-duty, it was just meant to be for oil & pad/rotor changes.
    I also have a limited number of hand tools, I think the largest extension size I have is 9" (I needed for my girlfriend's spark plugs on her V4 Toyota Camry).
    What other kinds of tools am I going to need to remove tie rods, etc? I'm also perusing other websites for more info on each step since: 1) I'm not the most experienced mechanic, 2) I have limited tools & time
    [Edit] I think I'm just going to hit the knuckle with a rubber mallet & a lot of brute force for tie rod separation. Is that a good idea?
    Last edited by Demi; 10-06-2013 at 04:48 PM. Reason: Learned more info while waiting for response.
  1. Power steering leaking, where to start??
    By Haulero in forum General Tech Discussion
    Last Post: 09-22-2011, 07:08 PM
  2. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  3. 98 with leaking steering rack
    By onlysr in forum Brakes/Suspension/Chassis
    Last Post: 01-22-2011, 12:03 AM
  4. Steering rack is leaking...
    By Matt in forum Brakes/Suspension/Chassis
    Last Post: 10-23-2009, 02:34 PM
  5. replaced power steering pump and now it is squeeling and leaking badly! Help
    By Cheri in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2009, 08:10 AM
