Thread: Jerks while reversing and in low gear
Results 1 to 8 of 8
macjoubert Jerks while reversing and in... 09-04-2013, 10:40 AM
genki Re: Jerks while reversing and... 09-04-2013, 03:24 PM
macjoubert Re: Jerks while reversing and... 09-14-2013, 04:30 PM
Scottydoggs Re: Jerks while reversing and... 09-14-2013, 04:36 PM
Bluemagic Re: Jerks while reversing and... 09-14-2013, 04:41 PM
L36 Killer Re: Jerks while reversing and... 09-14-2013, 04:33 PM
REDCRAPGP Re: Jerks while reversing and... 09-14-2013, 04:53 PM
macjoubert Re: Jerks while reversing and... 03-14-2014, 09:41 AM
  1. #1 Jerks while reversing and in low gear
    May 2013
    Flower Mound, TX
    Hello -
    I recently drove right over a curb at 30mph badly damaging my right wheel rim and destroyed my tire.
    Took it to the shop,was told to pretty much replace a lot of those parts as a precaution, cost me 4k more than the current value of the car , but I hate buying cars, anyways wanted to get another 2-3 yrs on my car.
    Now after 3 weeks the car jerks during reversing on the driveway or at work after the engine has been quiet for a long time.
    They are minor jerks, but Im worried that my 4k investment will come to naught if the jerks are due to an imminent transmission , engine problem.
    Any ideas on why this happens.
  2. #2 Re: Jerks while reversing and in low gear
    Donating Users
    Aug 2013
    Michigan, USA
    Check the transmission, something may have slipped I broke 3rd gear on my old manual transmission when I was trying to shift and hit a huge pothole at the same time. It was 2 AM and headlights from '82 Caviar doesn't do good in telling me there's a pothole big enough to swallow a beach ball whole. I spent the remaining 5 or 6 months I had with the car going from 2nd to 4th.
  3. #3 Re: Jerks while reversing and in low gear
    May 2013
    Flower Mound, TX
    Okay thanks for the response, I went to the shop here and they said it was the engine mounts, got them changed cost me a grand.
    For now the jerk is slight but still there.
    Sent from my Nexus 7 using Tapatalk 2
  4. #4 Re: Jerks while reversing and in low gear
    Quote Originally Posted by macjoubert View Post
    please tell me you had more then mounts changed for that 1,000 bucks....cause if not you got robbed.
  5. #5 Re: Jerks while reversing and in low gear
    Dec 2010
    DMV
    Like call the police robbed.
    Sent from my HTC One using Tapatalk 2
  6. #6 Re: Jerks while reversing and in low gear
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    I'm guessing you don't / can't work on your car ..
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  7. #7 Re: Jerks while reversing and in low gear
    Robbery!
    04 Comp G.
  8. #8 Re: Jerks while reversing and in low gear
    May 2013
    Flower Mound, TX
    Okay friends - I think problem is solved finally. So yes you saw that I took it to CBA for the engine mount replacement, that didnt help at all. This was before I decided to work on the car myself.
    So earlier the first thermostat was changed to 180F probably at around 75k miles (from the GM recommended 195), then I did another flush and another and and so on finally due to the overheating issue due to the bad radiator, decided to change the thermostat as well , this time I changed it to 195.
    Now there are very jerks , in fact the jerky movement is slowly ceasing.
    Also I am using the high mileage Lucas Fuel Treatment additive along with premium 93 gas, which I will use for probably 1000 or so miles.
    A few things, the noise has come down considerably, the engine does run hotter, 2 bars below midway (with the 180F it used to stay pegged at 1/4 ), but pickup and smoothness has returned, I now hear the same engine that I heard when I bought it 10 years ago!
    <Touch wood for all the positives in the post !>
    Thank you!
  1. Transmission jerks when car gets warm
    By Snapper in forum Introductions/Noob Questions
    Last Post: 03-15-2013, 05:18 PM
  2. jerks when shifting.
    By Kebo75 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2013, 06:35 AM
  3. Car Jerks at WOT
    By Joshmoshh in forum General Tech Discussion
    Last Post: 01-31-2013, 11:43 AM
  4. trans jerks after stop
    By grey08 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-03-2012, 08:45 PM
  5. jerks when shifting
    By kenneth74gt in forum General Tech Discussion
    Last Post: 01-04-2009, 01:23 PM
