Thread: Wrecked my baby now i gotta fix her and need help!!!!
Results 1 to 12 of 12
  1. #1 Wrecked my baby now i gotta fix her and need help!!!!
    Apr 2013
    Union City, In
    Went into a ditch and cracked my windshield, airbags went off, bent rad.
    My question is what all goes into replacing the rad? quick run down of how to take out and put a stock one back in?
    The airbags? how do i install/remove old ones? i have no idea so a little more info on these would be greatly apperciated!!!
  2. #2 Re: Wrecked my baby now i gotta fix her and need help!!!!
    the d/s air bag is held on by 4 small holes on the back of the wheel, you stick a screw driver in the hole, then turn it, while pulling on the corner of the bag, once it pops keep steady pulling on the one that popped, now pop the other one on the same side, then repeat for the other 2 on the other side, the harness pulls out of the air bag.
    not sure how the pass side comes out.
    you will want a new/used or send your out to be reset, air bag module, its under the carpet under the pass side seat, take the seat out, then the door sill trim, unhook the rug, pull it back, un do the harness, and the 3 bolts that hold it down.
    haven't done a rad yet but it cant be any harder then any other car, not much holds them in most of the time.
  3. #3 Re: Wrecked my baby now i gotta fix her and need help!!!!
    Hopefully you didnt damage the core support.
  4. #4 Re: Wrecked my baby now i gotta fix her and need help!!!!
    pics? I'm sure your condenser is messed up too if the radiator is bent.
  5. #5 Re: Wrecked my baby now i gotta fix her and need help!!!!
    Pull dash to replace passenger air bag. You'll need to have the module reset with a good scanner
  6. #6 Re: Wrecked my baby now i gotta fix her and need help!!!!
    Apr 2013
    Union City, In
    I will take pic tonight and post, rad isn't bad bend just a slight bend. The main reason replacing is bc sensor inside rad is bad
  7. #7 Re: Wrecked my baby now i gotta fix her and need help!!!!
    what sensor? the low coolant sensor? that can be changed with the rad still in the car.
  8. #8 Re: Wrecked my baby now i gotta fix her and need help!!!!
    Or just unplugged and ignored
  9. #9 Re: Wrecked my baby now i gotta fix her and need help!!!!
    Apr 2013
    Union City, In
    It is currently unplugged and being ignored lol and looking at it today there is only a slight bend in the metal on the bottom of the rad. It is just barely touching the rad.
  10. #10 Re: Wrecked my baby now i gotta fix her and need help!!!!
    A bend in the metal under the rad? You mean the subframe? That's kinda a big thing
  11. #11 Re: Wrecked my baby now i gotta fix her and need help!!!!
    Apr 2013
    Union City, In
    yeah there is alot of damage. i am looking for another grand prix body that has a blown motor or tran/both.
  12. #12 Re: Wrecked my baby now i gotta fix her and need help!!!!
    I know where there is a 99 gtp with blown motor $800 In Celina
  1. wrecked GP :(
    By Malaki in forum General Grand Prix Discussion
    Last Post: 08-30-2012, 01:41 PM
  2. Wrecked FR-S
    By TLSheff in forum Off Topic Discussion
    Last Post: 06-19-2012, 11:05 PM
  3. Almost wrecked my gtp
    By pontiacGTP123 in forum Off Topic Discussion
    Last Post: 04-09-2009, 12:46 AM
  4. gtp is wrecked...
    By 2000GTP in forum Off Topic Discussion
    Last Post: 11-17-2008, 04:47 PM
  5. wrecked the GTP.
    By shaferz in forum Off Topic Discussion
    Last Post: 08-07-2008, 05:46 PM
