Thread: Dash light problems plz help
Results 1 to 3 of 3
  1. #1 Dash light problems plz help
    Jul 2013
    Logansport, IN
    I have a 2000 GT the other night getting close to dark when headlights usually turn on and dash lights kick on and dim i noticed this wasnt happening. I tried manually turning on lights n noticed my dash lights come on a lil brighter then quickly dimmed out to nothing!! I stoped to assure i had headlights n tails wich I did so I went on. A few mins later smoke started rolling outta dash at headlight switch n lost headlights n all, I quickly pulled over n unplugged the switch wich had already started to melt at plug in. Today I replaced switch and plug in and have all head n tail lights but when headlights come on or are manually turned on dash lights brighten up n quickly fade out to nothing, except for Radio and Info screen. Im lost plz help!!!!!!
  2. #2 Re: Dash light problems plz help
    St. Louis
    Might have cooked the DRL module. And since the headlight switch started to melt you may want to check the plug again and make sure that no wires have melted their insulation and are grounding out behind the dash.
  3. #3 Re: Dash light problems plz help
    Jul 2013
    Logansport, IN
    Found the issue after hrs of searching it was the illumination wires, wich were never connected or capped off after a New CD player was installed.
  1. dash lights some courtesy problems..
    By tyler930 in forum General Tech Discussion
    Last Post: 02-10-2013, 01:41 PM
  2. Certain light out in dash?
    By Godfather in forum Visual/Body Modifications
    Last Post: 07-20-2011, 01:34 PM
  3. dash problems
    By SilvaMan61 in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2010, 07:11 PM
  4. Problems with dash?
    By ChrisJ in forum General Tech Discussion
    Last Post: 06-23-2009, 01:32 PM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
