Thread: Pulley drop time?
Results 1 to 20 of 20
jman44 Pulley drop time? 07-08-2013, 06:21 PM
Matt Palm Re: Pulley drop time? 07-08-2013, 06:26 PM
jman44 Re: Pulley drop time? 07-08-2013, 06:27 PM
REDCRAPGP Re: Pulley drop time? 07-08-2013, 06:27 PM
Matt Palm Re: Pulley drop time? 07-08-2013, 06:28 PM
matt5112 Re: Pulley drop time? 07-08-2013, 10:09 PM
jman44 Re: Pulley drop time? 07-09-2013, 11:20 AM
jman44 Re: Pulley drop time? 07-08-2013, 06:32 PM
REDCRAPGP Re: Pulley drop time? 07-08-2013, 06:34 PM
tms8582 Re: Pulley drop time? 07-08-2013, 10:43 PM
Elite6 Re: Pulley drop time? 07-09-2013, 12:15 PM
tms8582 Re: Pulley drop time? 07-09-2013, 08:43 PM
ILoveAudi Re: Pulley drop time? 07-09-2013, 07:45 PM
Fivefingerdeathpunch Re: Pulley drop time? 07-09-2013, 08:13 PM
ILoveAudi Re: Pulley drop time? 07-09-2013, 08:19 PM
Fivefingerdeathpunch Re: Pulley drop time? 07-09-2013, 08:30 PM
ILoveAudi Re: Pulley drop time? 07-09-2013, 08:42 PM
Fivefingerdeathpunch Re: Pulley drop time? 07-09-2013, 08:52 PM
hollas13 Re: Pulley drop time? 07-10-2013, 07:32 AM
tms8582 Re: Pulley drop time? 07-10-2013, 09:18 AM
  1. #1 Pulley drop time?
    Apr 2013
    Union City, In
    I have a 99 gp gtp coupe. has speed daddy headers, no cat, magna flow mufflers, roller rockers. My question is what can i safely drop to on my s/c and run kr free?
  2. #2 Re: Pulley drop time?
    antioch ill
    i wouldnt say kr free but you could drop but id deff get a tune first
  3. #3 Re: Pulley drop time?
    Apr 2013
    Union City, In
    why should i get a tune first????
  4. #4 Re: Pulley drop time?
    You need something to scan knock with..then that'll tell you what size pulley u can run
    04 Comp G.
  5. #5 Re: Pulley drop time?
    antioch ill
    so you dont run it lean and chip a piston or it runs too rich and fuel wash it
  6. #6 Re: Pulley drop time?
    Quote Originally Posted by Matt Palm View Post
    That's so completely wrong.
    The stock tune isn't lean by any stretch of the imagination.
    The canned tunes tend to run around the same or richer.
    Changing the pulley doesn't affect the required MAF calibration. Changing your intake does. And that's about the only thing the PCM cares about when you go WOT.
    Just scan, and adjust pulley accordingly.
  7. #7 Re: Pulley drop time?
    Apr 2013
    Union City, In
    Thanks for the info!
  8. #8 Re: Pulley drop time?
    Apr 2013
    Union City, In
    alright thanks
  9. #9 Re: Pulley drop time?
    Invest in a aeroforce scan gauge first before you even think about dropping pulleys.
    04 Comp G.
  10. #10 Re: Pulley drop time?
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Quote Originally Posted by jman44 View Post
    I'd guess you can go with a 3.4 without KR but like the others mentioned a scan gauge would be smart. I'm assuming you have an intake also right? I'm running a 3.3 with similar mods except for a mild cam and a little bowl porting on the heads. I have an Aeroforce and have not shown any KR. I've got a 3.2 on the way and will keep an eye out for knock.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  11. #11 Re: Pulley drop time?
    Cambridge, Ontario Canada
    Quote Originally Posted by tms8582 View Post
    Factory programmed PCM or something else?
    2005 E55 - stock
  12. #12 Re: Pulley drop time?
    Washington Michigan
    Quote Originally Posted by Elite6 View Post
    I was running a factory tune without any KR but I did have my buddy change the fans to come on sooner. That's one area where the factory tune really sucks imo. The fans don't come on until 220... Now I have an intense tune with raised shift points. Both tunes showed zero KR. I can't say the Intense tune made a huge difference except for the higher shift points. In fact I think I'll even raise the shift points higher because the motor really pulls over 6000. I think the balanced crank, Xtreme cam and 105 springs can really handle some RPM's. Right now the car shifts at 6300 and I will change that to 6500. I'm going to give the 3.2 a try and maybe increase the WOT timing a little too and keep a close eye out for KR. he original poster talked about rockers... I assume he meant 1.9 rockers? If so I's guess he will be good with headers and rockers and a 3.4.
  13. #13 Re: Pulley drop time?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    As far as the pulley drop and everything, hit up zzp's 3800 section on their website. They have info on the order of mods to do and how big to go with mods. Just check it out!
  14. #14 Re: Pulley drop time?
    Quote Originally Posted by ILoveGM View Post
    I prefer to never follow what ZZP says.
  15. #15 Re: Pulley drop time?
    Aug 2012
    Well, I've never heard anything bad about them! But everyone has their own opinion! Why do you disagree with them?
  16. #16 Re: Pulley drop time?
    The parts for the most part are good and customer service is mostly good these days, havent seen many people have issue lately.
    Is just the way they say you can add mods is whats wrong. The first build sheet says all you need to run a 3.4 pulley is a 180 thermostat, colder plugs, their pcm and a downpipe. I bet for just about any car, it will still see a decent amount of KR and need for exhaust flow to be safer.
  17. #17 Re: Pulley drop time?
    Aug 2012
    I didn't think that was all they said. Maybe for a 3.6 or 3.5 pulley. I don't know. Oh well lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  18. #18 Re: Pulley drop time?
    I bet the PCM runs pretty rich too, its how most mail in tune battle the KR.
  19. #19 Re: Pulley drop time?
    Jul 2013
    adrian, mi
    how does a tuned pcm get rid of kr? i have ported manifolds, cai, 180 tstat, al 104's, 3" dp and a 3.4 mps i want to put on. also i have a way to scan.
  20. #20 Re: Pulley drop time?
    Washington Michigan
    Quote Originally Posted by hollas13 View Post
    I am not an expert on tuning by a long shot but I know if you had a custom tune on a dyno they could tell right away what pulley you should run safely. They do this by an educated guess on the pulley size then dyno the car and pulley down a size or two if they can without KR. A lean fuel/air mixture can result in KR the stock PCM adjusts the amount of fuel based on the MAF and O2 readings. I'm guessing that some tunes may include adjustments to the fuel trims and increase the fuel mixture to eliminate a possible lean condition. I think with lightly modded cars with stock injectors this is not much of an issue with even a stock tune. The easiest way to get KR is to not have good exhaust flow and run a pulley too small. Your jamming to much hot compressed air into the cylinders and the hot gasses don't flow out fast enough causing excessive heat and early detonation (KR) I topped off my build with a tune from Intense. John really knows his stuff and you can call him with questions if you need to. INTENSE-Racing.com: INTENSEâ„¢ Reprogrammed 3800 Powertrain Control Module (PCM) The web site lets you choose a canned tune based on your mods.
  1. Should i drop to a 2.8 pulley?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2013, 12:43 PM
  2. pulley drop help!
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 09-12-2012, 11:32 PM
  3. what pulley can i drop to with each option
    By nascartech in forum General Tech Discussion
    Last Post: 01-06-2012, 02:36 AM
  4. Pulley drop
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2011, 10:52 PM
  5. pulley drop 05
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2010, 07:51 AM
