Looking for a bit of insight for my 01 gt, 3.8.
Leaking oil, fairly aggressively. I have changed oil pan and valve cover gaskets rescently.
Getting 'low coolant' light, although coolant level seems OK, although it does appear to have oily substance in it.
and the coolant has be changed within the last year.
Belt is flinging something upward to the underside of the hood, and I don't seem to be having any major fluid issues(a bit of power steering and brake fluids from time to time, and oil is disappearing at a quart per every two weeks, give or take. I have heard about LIM gasket failures, could this be a culprit? Would oil in the antifreeze give the sensor a false reading calling out 'low coolant'?, because the level doesn't seem to change. Oil level sure does though. Thanks in advance for any and all input.
