Thread: Problem with my AC not working
Results 1 to 7 of 7
  1. #1 Problem with my AC not working
    Jun 2013
    MILLEDGEVILLE, GA
    Hello,
    I recently bought a 2000 Pontiac Grand Prix 3.1 ... I believe that is what it is... but i am having a problem with my air conditioner... i bought a recharge kit and it worked for maybe 5 minutes before it continued to blow hot air. Does anyone know how I can go about finding out what the problem so I can get it fixed without having to spend a bunch of money at a mechanics shop for something that I could have done my self.
    Thanks all...
    Sincerely,
    A VERY hot driver
  2. #2 Re: Problem with my AC not working
    if you follow all the a/c lines under the hood you should find a real greasy/dirty seal, or connection, that would be the oil leaking out of the a/c system. then work on repairing or replacing whats needed.
  3. #3 Re: Problem with my AC not working
    Put some uv dye in it
  4. #4 Re: Problem with my AC not working
    SE Level Member BD3511's Avatar
    May 2012
    Sheffield Lake,Ohio
    Same thing happened to mine. Ended up being the compressor was toast on my car it was a nightmare getting too on the 3.1 I'm sure it wouldn't be that bad.
    Sent from my HTC6435LVW using Tapatalk 2
    1998 Grand Prix 2D GTP-Silver**2002 Trans am WS6 6 speed**1988 Trans am 5.7 Turbo
    1988 Trans am GTA 5 speed-100% OEM
    1997 BMW M3
    2001 Ford F150 EXT- Towing/pulling/plowing
  5. #5 Re: Problem with my AC not working
    A nightmare on a 3.8? It's super accessable on a 3.8. Likely in the same location etc being the same body on the 3.1 engine.
  6. #6 Re: Problem with my AC not working
    May 2012
    Sheffield Lake,Ohio
    I had problems thank god I had the swivel end and impact gun. I tried from the top and couldn't because the SC snout. So I went from the bottom and just fought with it. I'm sure there was/is an easier way I'm just still learning my ways around the 3800 .
    1997 BMW M3
  7. #7 Re: Problem with my AC not working
    Dec 2012
    Where 4T65E's were born
    Sold.
  1. A/C not working!! what could be the problem
    By jayroca in forum General Tech Discussion
    Last Post: 01-23-2013, 03:17 PM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Replies: 1
    Last Post: 01-11-2012, 11:38 PM
  4. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
  5. problem #2.. #5 on heat control not working
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 12:13 PM
