Thread: No 4th gear/ overdrive/ lockup
Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
  1. #1 Re: No 4th gear/ overdrive/ lockup
    Dave at Triple Edge has seen a lot more than me and clearly I'm going off info from guys like him. Here's a link to his site. Only mentions the hub. If he saw the female end as an issue, he'd have mentioned it. I think you have one of the few issues ones. Also I suppose the piston or seal on your 4th stator support may be bad.
    No 4th Gear
  2. #2 Re: No 4th gear/ overdrive/ lockup
    TCC only engages in 3rd and 4th gears though. I'm off to look at something
  3. #3 Re: No 4th gear/ overdrive/ lockup
    Mar 2013
    Green Bay, Wisconsin
    Thanks Billboost for your help on this. If you dont have 4th gear/ overdrive look into the 4th gear hub and input sun gear that it goes into. If the gear hub does not go in atleast 1/2"... replace the input sun gear.
  1. Lockup = Vibration?
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 10:01 PM
  2. No Overdrive/4th gear...need help
    By AZGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2011, 01:48 PM
  3. anyone else running no tcc lockup?
    By 99prixgt in forum PCM Tuning
    Last Post: 09-16-2010, 10:23 PM
  4. Tranny shifts from 2nd gear to Overdrive?!?!?
    By atrainbynight in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2009, 04:14 PM
  5. tcc lockup disabling???
    By 513yj in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2009, 10:08 AM
