Thread: High RPM's when starting up my 98 GTP
Results 1 to 12 of 12
  1. #1 High RPM's when starting up my 98 GTP
    Jun 2013
    Lincoln
    I was wanting to know if there was anyone who could help me out with my problem. Whenever I start my car it rev's up into high RPMS and then when you shift it into reverse or drive it will shift hard and the RPM's will go down. The service engine soon light it is on. Stated that there was a bad TPS Sensor and Banks 1 was running lean. I replaced the TPS sensor and the problem didn't go away. Any more advice for me?
  2. #2 Re: High RPM's when starting up my 98 GTP
    Dec 2012
    Where 4T65E's were born
    Vacuum leak? Check while running by listening for a sucking sound, or if it's not that easy, spraying carb cleaner, or TB cleaner on the intake areas so see if the idle changes.
    Sold.
  3. #3 Re: High RPM's when starting up my 98 GTP
    p0171 code? Vacuum leak.
  4. #4 Re: High RPM's when starting up my 98 GTP
    Jun 2013
    Lincoln
    at work right now, will hafta check on it tomorrow. That's one thing I was gonna look at. Any idea of what certain vaccum hose it would be?
  5. #5 Re: High RPM's when starting up my 98 GTP
    the T's break, the evap fat line of the TB likes to break, mostly its the ends of the lines where they slip on to sensors, or to t a vac tree on the super charger.
    the T under the snout is famous for breaking. as well as the one on the fpr.
  6. #6 Re: High RPM's when starting up my 98 GTP
    Jun 2013
    Lincoln
    is this a easy fix? I'm new to Pontiac stuff...
  7. #7 Re: High RPM's when starting up my 98 GTP
    Yeah it's a really simple fix. Get a couple of vacuum t's and some vacuum hose
  8. #8 Re: High RPM's when starting up my 98 GTP
    look for small plastic T's the best ones i could find were at advance auto, 2 per pack for 2 bucks, then 3 bucks in vac line, 3 feet or so will do.
    this fat vac line off the TB the one thats bent over to the back to a plastic line, i got 4 or 5 inches of that, stuck the thinner line into the fat one to reduce it to fit the plastic stock line. this is the evap vac line
    this was the old plastic line that was replace from pic one on the front of the engine. the ends or T's break or wear out and get loose.
  9. #9 Re: High RPM's when starting up my 98 GTP
    Jun 2013
    Lincoln
    UPDATE: Took off the engine cover and realized that the vaccume line had split it half. Got a new one and put it on and erased the code and it did the same thing and read the codes Throttle position sensor low circuit and also banks 1 was running lean. Not sure what to do next, any suggestions!?
  10. #10 Re: High RPM's when starting up my 98 GTP
    Check for more vacuum leaks and pull the tps and clean it
  11. #11 Re: High RPM's when starting up my 98 GTP
    Jun 2013
    Lincoln
    just recently replaced the throttle position sensor and sprayed around to see if there were any vaccumm leaks.
  12. #12 Re: High RPM's when starting up my 98 GTP
    Jun 2013
    Lincoln
    it is fixed!!. Come to find out all it was is the Throttle Position Sensor Connector. There was a short within it.
  1. starting
    By Tyler Sharp in forum General Grand Prix Discussion
    Last Post: 08-14-2012, 02:23 AM
  2. High Idle When Starting
    By DrNoodles in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-06-2011, 08:43 AM
  3. Need Help Please with not starting
    By flaspeeder in forum General Tech Discussion
    Last Post: 10-24-2011, 04:13 PM
  4. Just Starting!
    By fpgt17 in forum Introductions/Noob Questions
    Last Post: 01-17-2011, 01:01 PM
  5. Starting to Mod
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 05:04 AM
