iirc normal can go up to 6-8* KR on some motors. The difference is on a 3.4 6-8* KR is like 16-18* KR on a stock pulley. The smaller you go on pulley, or more mods you throw at the car, the smaller the window is for KR and the motor holding together.
Ideally, on a 3.4 you want less than 2* KR peak, preferrably 0 KR across the WOT range and shifts if you plan to go with a smaller pulley. Rocking the 3.4 as it is, if its knocking at all, consider running full headers since he wants to drop pulley even more, AL104s, alki/meth/Intercooler setup of some kind... or have him buy a cam and keep the 3.4 and not worry about it.
Hes going full headers with downpipe and he has 104's now as of 2 days ago found out both the gold an his gtp were running factory plugs and can he put a fmic on it or does he have to go to a zzp kit?
