Thread: Growling/Grinding at 2000-2400 RPM
Results 1 to 4 of 4
  1. #1 Growling/Grinding at 2000-2400 RPM
    May 2013
    Madison Wi
    I have a 2000 GP GT with the 3800II. Recently I have been hearing a noise from the front end/tranny around 2000-2400 rpm. It usually does it on acceleration and it dogs a bit. It will not downshift as fast when you hammer on it and it is in that range. It has been happening for about 2 months or so but has gotten worse.. Its most noticeable when going about 35-40mph and you have to speed up fast. Sounds like a grinding/growling noise and it changes in tone. Background on the car: Bought 3 years ago from GM dealership. 2 weeks after purchase the tranny blew inside the case.. only 1 gear left.. Had it completely rebuilt at a local trans shop by my house(Dealership would not replace because I would not pay the tow bill to have it hauled 60 miles north. They wanted their technician to look at it but wouldn't fork for the bill...). 3k later it had a new tranny. 2 months after that it was smashed into by a texting and driving driver... Would have totaled it if the brand new tranny wasn't put in. Poor lady had to pay to fix my car.. No front end damage occurred during the accident. Have had engine work done since(General things: Valve cover gaskets, seals, top end) as well as left side drive hub and joint. I have no idea what is wrong with it and it is driving my crazy!! Please HELP!!
  2. #2 Re: Growling/Grinding at 2000-2400 RPM
    Hmmm thinking about this.. what could make noise at that rpm? I had a thought about a wheel bearing. Did you hear the one that went bad, anything like that?
  3. #3 Re: Growling/Grinding at 2000-2400 RPM
    May 2013
    Fingerlakes region of NY
    sounds like a wheel bearing to me, also check your trans fluid, any check engine light?
  4. #4 Re: Growling/Grinding at 2000-2400 RPM
    May 2013
    Madison Wi
    I recently replaced the tranny fluid and filter because it had about 30k on fresh rebuild. Was supposed to be done at 25k. No CELs. I will check both wheel bearings again. Noticed it was a little different sound last night and now I can feel a slight vibration in the gas pedal. Drivin me nuts!
  1. RPM'S Flutter between 1700-2400 under load in 3rd-4th gear.
    By jdebus97 in forum General Grand Prix Discussion
    Last Post: 03-15-2017, 01:41 PM
  2. 2000 GTP Grinding-ish Noise with Hard Acceleration
    By epon in forum General Tech Discussion
    Last Post: 07-04-2013, 02:44 PM
  3. Growling and grinding
    By gmoss1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2011, 01:21 PM
  4. growling noise
    By tjs84c10 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-13-2008, 02:06 AM
