AT 120k, recently went through and replaced wheel bearings with Timkens all the way around, Monroe quick struts all the way around, power steering and ATF fluid swap, new serp belts, new tires, aligned etc.
All this work was done pretty close to each other so I'm not sure if its related to something that was done in the service.
I'm now getting a muffled low pitched grinding/rubbing noise under hard acceleration from a stop. Under normal driving, no noise and feels like it's shifting well. I can duplicate/ increase the noise a tiny bit by stepping on the brake and giving it a lot of gas at a stop (without moving) so I'm shying away from the CV joint with a torn boot as the culprit. (silent under low throttle and no clicking in turns). Noise is also apparent when hard accelerating at speed also. Torque converter slipping?
When I changed the ATF and filter, I left the old filter's oring in the housing and just pushed the new filter into it. It seemed like it was snug and fully seated. Old fluid was good and red and didn't stink. ATF levels are good.
When I changed the struts I didn't grease the top of the plates or strut bearings, wondering if maybe they're shifting around slightly under torque.
Took it to a shop and they can hear it but aren't sure, suggested maybe loose exhaust but that doesn't make sense given the symptoms.
Searched around and found a few instances of same symptoms but no resolutions.
Help?
